Hydraulic Jack for GLK
Old Apr 28, 2012 | 11:07 PM
sg07's Avatar
SLK350
Would a 2 ton hydraulic jack be sufficient for DIY winter/summer tire swap? I believe the curb weight for a GLK is more than 2 ton but when changing tires, you technically only lift up a quarter of the vehicle. Is my logic making sense?
Old Apr 29, 2012 | 11:14 AM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
Makes "cents", but not worth it.
Spend for a heavier jack. The 2 ton's I have seen and used wont lift high enough for a SUV, and you will find yourself building some type of dangerous extension to get enough lift to raise the tire, or positioning the jack in an area where it is subject to side load movements. The frames of the 2 ton's aren't sturdy enough to resist side loads and the vehicle may topple.
Try this 3 ton or better, and I would buy from a place where you can get repairs at a later date.
Old Apr 29, 2012 | 03:30 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
You should be more than sufficient if you jack up one corner at a time, I don't mean with the $20 2-Ton jack you buy from Walmart.
I got two of these Jack from Barbor Freight to lift the whole front OR rear wheels up at the same time. Changing wheels out is easy and take less time than to do one corner at a time.
http://www.harborfreight.com/2-ton-l...ump-68051.html
Old Apr 30, 2012 | 02:03 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
I have a dumb question...where do you place the lift point of the jack if you are not using the lift points on the side of the car? Will that not damage anything on the car if you use a different lift point? I have a 3 ton hydraulic lift jack but didn't have the ***** to use it as I am too afraid to use it and damage a expensive car.
Old Apr 30, 2012 | 03:02 PM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
ditto... make sure that whatever jack you get is able to raise high enough for a SUV.
