Bluetooth Issues
Old Sep 10, 2012 | 08:11 PM
VishGLK350's Avatar
GLK350
Bluetooth Issues
I've had a 2012 GLK for about 5 months now. When I turned on the car today as soon as the Bluetooth connected to my phone I lost sound to the Audio (radio/sat). When I take the Bluetooth off the audio comes back on but as soon as I reconnect the audio goes. Any ideas on how this could happen? I couldn't find anything in the owner's manual or command manual.
Old Sep 10, 2012 | 11:30 PM
BoxsterT's Avatar
00 Boxster 11 GLK350 04 C230 96 TrooperLS
This happened to me as well...Here is how I fixed it
Your car blue tooth is currently synching to your phone media player, causing it to look for audio files on your phone instead of telephony. You need to disable this link. I suggest your clear out all your BT links then re-establish phone as the only device linked to your head unit. Refer to owner manual for these steps. Good luck.
Old Sep 13, 2012 | 04:55 PM
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
Wow, killer solution BoxterT!
Old Sep 13, 2012 | 05:31 PM
VishGLK350's Avatar
GLK350
Thank You BoxsterT
I reset the Bluetooth and everything looks to be working well. Thank you again for the advice.
Old Sep 14, 2012 | 03:41 AM
N91K's Avatar
GLK350, G55, AMG GTS, C63 507
Happened to me once too, but figured it out and everything's back to normal!
Old Sep 14, 2012 | 10:24 AM
BoxsterT's Avatar
You all are very welcome, here's one for you...
On my '11 GLK, the USB connection to my jump drive sometimes lose signal and the display goes "NO USB", I had to unplug and re-plug to have the drive recognized again. I currently rigged a longer USB extension to the driver side near my knee to make it easier w/o having to open the glove box. Any suggestion?
PS: I changed several brands of jump drives in various capacity and file sizes to no avail.
Old Sep 14, 2012 | 11:17 AM
kozak79's Avatar
2015 GLA250 4MATIC
Does the '11 have an SDHC slot like the '13? They make 128GB SDHC Cards.
Old Sep 14, 2012 | 11:25 AM
BoxsterT's Avatar
Mine are more basic
It has the iPod kit and USB connector in the glovebox.
Old Sep 14, 2012 | 11:45 AM
kozak79's Avatar
2015 GLA250 4MATIC
So looked it up and you should have a PCMCIA card slot. You can get an adapter and any kind of memory card to use with the adapter. For instance here's an option:
Adapter:
Amazon Amazon
Memory Card:
64GB -
Amazon Amazon
This should work, but no guarantees.
Old Sep 14, 2012 | 03:48 PM
ble2716's Avatar
Very very slow
Have you tried another USB extension cable? or plug your phone directly to USB port in glove box to eliminate then extension altogether.
I have had bad USB extension cable before.
Old Sep 14, 2012 | 06:28 PM
rmfnla's Avatar
That was going to be my suggestion as well.
Always test connectors first...
Old Sep 16, 2012 | 10:47 AM
BoxsterT's Avatar
Obviously it's not common problem
Must be something else wrong, the extension cable not at fault because the original plug in glovebox had same issue please reread my original post but thanks guys!
