Removing lower door trim
Does anyone know if the lower chrome door trim is just held on by double sided tape or if its also held on by plastic clips that snap into small holes.
Thanks for the help
Thanks for the help
I'm going to paint match everything on the merc. If there are no holes in the doors then they will get removed. I just wanted to see if any one has removed one or replaced one
2024 GLC300, 2014 BMW M235i
Wouldn't your servicing dealership have the answer? I'm sure they could find the answer in their service manuals, exploded views, and all that [?].
3.5L
3.5L
After doing some research the lower chrome door trim on all 4 doors is held on with double sided tape.
So today I removed all the lower chrome door trim using my heat gun and pulling it off pretty slow.
And then I used an eraser wheel on the end of my drill to get all the remainder of the tape off.
Then used some prepsol to clean the areas where the trim was.
Then I buffed all 4 doors out with #3 3M fine perfect it and then added a coat of wax. The car will get a full detail after I'm finished paint matching everything.
Sorry for the crappy pics, I'll get some better ones tomorrow
![](http://i58.photobucket.com/albums/g270/BIGDUB1/PB065164.jpg)
![](http://i58.photobucket.com/albums/g270/BIGDUB1/PB065166.jpg)
Just a heads up on the lower chrome trim on the corners of the rear bumper:It is held on by a bunch of plastic clips that snap threw the rear bumper. So if you plan to remove it, the mounting holes will have to be shaved and the rear bumper cover repainted.
