Rear seat reading lights?
My owner's manual shows two individual reading lights with individual on/off switches for the rear seat passengers. But our 2011 GLK with the panorama sunroof has nothing of the sort - it has a single light, which cannot even be turned on/off from the rear seat, only from the front overhead console.
Is this normal?
Is this normal?
2015 X3 M Sport, 2014 ML350
I believe these lights were a part of the leather package, which included additional cabin lighting. I have MB Tex and have the same rear light you described.
I wonder if I can retrofit the optional overhead lights into my GLK?
350 GLK, C280
Maybe not so easy. Remember most switches on these new vehicles are not in the power line but are just digital inputs to the microprocessor. The computer turns on and off power to the device. That way the switches are in the low current loop and need only be small contacts, read cheap and less prone to contact burn, and not big to carry the full current demand of the actual device. This is why you can't power your Radar detector from the lines in the front overhead light box. So it may take a program change to actually have the power wires to those lights turned on.
350 GLK, C280
Be original, get those lights that look like light bulbs from that guy on TV. No connections, they are battery powered. Pull chain switch. Just Velcro them up and your GLK will be special. You might need some lamp shades to help the driver see, but any good lamp store should have the clip on type.
