excessive road noise
Old Apr 16, 2013 | 09:14 AM
bghart2003's Avatar
2010 E CLASS COUPE 350
Hello, I own a 2012 GLK 350 4matic....love the vehicle....only one issue....on course concrete roads I have (what I think to be) excessive road noise coming primarily from the front of the car....is this to be considered "normal"....some is obviously from the tires but I feel that there's noise resulting from somewhere else....anyone one else with this situation?
Old Apr 16, 2013 | 10:39 PM
Rascally Wabbit's Avatar
2010 Mercedes GLK 350, 2001 BMW Z3 3.0 Roadster, 1997 Cherokee XJ
What brand of tyres do you have & size? Possibly an alignment issue?
Old Apr 16, 2013 | 11:42 PM
Oldengineer's Avatar
GLK350 4matic
Check your tires and see if you've got unusual wear patterns or scalloping. Could well be an alignment or wheel balance issue.
Regards:
Oldengineer
Old Apr 17, 2013 | 09:07 AM
bghart2003's Avatar
thanks guys for responding.....the tires are Continentals....so far the wear looks even and regular.....didn't think about the "balance".....I will most certainly check that out....thanks again!!
Old Apr 17, 2013 | 09:39 AM
bop11's Avatar
350 GLK, C280
How many miles on tires? I had Scorpions on a vehicle that were quite when new but became very loud as they wore. I like the tire but knew when to change them. The little wear indicators have an effect on the air passage and can generate noise as they get close to the surface. Is the noise only on concrete? Many areas are grooving concrete for drainage. Also notice if there is a Jersey Barrier next to you when you get the noise (reflection)
Then again noise is subjective. Without a dB meter, whats loud to you may be almost in-audible to my old ear. If it were exhaust note, no one would complain.
Old Apr 17, 2013 | 01:03 PM
ble2716's Avatar
Very very slow
I have scorpion tires on my car and it does make louder noises when I am on concrete highway (407ETR).
In fact, all the car that I've driven on this highway makes a quite a bit of noises. GLK has the least noise compare to other cars I have driven.
Old Apr 18, 2013 | 05:02 PM
MBNA109's Avatar
2015 VW GTI.S4; 2016 Audi Q3 Prestige
Concrete will NEVER be soft or low noise vs. asphalt.
