Changing steering wheel
- yes shifts show on screen. The cruise control lever also has a speed limiter setting (if set cannot go over set speed with gas pedal have to hit brake first) This all sounds complicated but it isn't and is easy to do and as long as you disconnect the NEGATIVE battery lead before you do anything there will not be any trouble codes or need to go to the dealer.
Contact plate has to be one that can interface with car computer on your specific model. I only changed levers module so that the lights on the wheel would work but I could have left the original and everything would work except for the button lights. C class forum has lots of posts about all this.
All my correspondence with supplier was thru his ebay email address above. This person sells many Mercedes steering wheels and really seemed to know everything about compatibility and part numbers. He worked with me for weeks getting everything to work right. Top rated seller. Don't be put off from his location every Mercedes part was shipped from Germany.
