Traction Control Issue?
Temperature was 8C and the road was dry and sunny. Vehicle has about 6000km.
I pressed the disable button and the light showing it disabled came on. The TC remained in force though. After I cycled the enable button a number of times the TC light went off. After that the problem went away.
Anyone seen anything like this.
@iewoals: It was only the traction control light that went on, not the red line graphic suggesting I'd crossed over. That always causes a pull to the opposite direction.
This was traction control like I used to experience on my Saturn VUE on an icy driveway. Press the gas pedal all the way to the floor and the engine slows down and the wheels don't turn.
And again, what was really peculiar was when I disabled the traction control and the indicator light showed it disabled, the other indicator that shows when it's working still went on and off.
I am not too familiar with the GLK yet, but I think I read that you can deactivate ESP. But when you do that, Traction Control is not deactivated.
I would go to dealer, explain exactly what happened and try and speak to an actual MB trained technician , rather than a service supervisor. Even if they only explain how the system works, it might be worthwhile. Your post has alerted me to do same!
Next service they checked but no fault codes or problems reported. Very strange.
