Mirror Problem - urgent
Old Jan 28, 2014 | 06:17 PM
107123210's Avatar
We have GLK250 packed & ready for long road trip. But noticed a problem with the passenger side mirror.
Mirrors fold in on both sides as they should. However, when mirrors are opened, the passenger side goes way forward and faces outward instead of back, while the driver side works as it should.
Has anyone experienced this and know if there is an easy fix? No time to go to dealer before we leave.
Old Jan 28, 2014 | 07:46 PM
jiwengang's Avatar
2014 GLK 350 4Matic
By Design they can go outward or forward. So can you manually adjust it to correct position?
Old Jan 28, 2014 | 08:55 PM
107123210's Avatar
From what I have read, the electric folding mirrors may only be fitted in Canada.
To answer your question. When the mirrors are unfolded, the drivers side folds out and stops at the proper position but the passenger side keeps going and ends up facing outwards away from car.
It can be manually pushed back to where it should be. There is a click as it is pushed out of its wide open position. But there is nothing to hold it in the new position - I am sure wind and vibration would cause it to move. Maybe I could duck tape in position? On a brand new (under 600km) Mercedes!
I did a search and found that this has been a problem since 2008, maybe earlier on other models of MB. Maybe that is why MBUSA didn't get them on GLk?
The manual gives a method of resetting the mirrors by holding fold button down for a short while after folding, but that did not work. I heard the clicks and bang they mentioned, but it did not solve problem.
Old Jan 28, 2014 | 10:57 PM
Cwdawson's Avatar
Fj cruiser 2014 GLK250
If resetting it did not help it sounds like a service may be needed... Since you are going on a trip and this would be pretty annoying (To me anyways) I would turn off the feature and deal with it when you get back. I turned ours off for the extreme cold so as not to damage them and turned them back on upon returning to the warmer weather...
Old Jan 29, 2014 | 07:45 AM
fcch's Avatar
SLK 350 2013
Does sound like you'll need a visit to the dealer.
I also turned off the feature for the winter. When they would unfold in the morning, there would be a lot of crunching and grinding because the blowing snow over night would be binding somewhere in the joint.
Sorry to hear about this ... DO have a good trip.
Old Jan 29, 2014 | 08:12 AM
107123210's Avatar
I am operating the mirrors manually, so don't know what I could turn off. All I need is for the passenger side mirror to stay in the proper position. I am going to stop at dealer on way out in a few minutes. May just be frozen or maybe something broke he says.
Old Jan 29, 2014 | 06:10 PM
ble2716's Avatar
Very very slow
You could disable the mirrors from opening and closing every time your lock or unlock the car. I am pretty sure it's in the manual somewhere.
Anyway, on your steering wheel, push left or right arrow>settings>convenience>down arrow>"Fold Mirrors in when locking">change it to "disabled".
This will allow you manually adjust your mirrors until you see the dealer.
Old Jan 30, 2014 | 08:34 PM
107123210's Avatar
I never did have the mirrors set to close when I locked car.
On way out of town, I stopped at dealer. They checked mirror, hooked car to Star and confirmed that there is a problem somewhere in electronics. Apparently one of two things, each of which would cost over $1000! Under warranty of course. THey did set mirror in a fixed position and we have made it safely so far to Carolinas. May just leave it until we get back in April.
Car ran well on way down. Mileage not as good as it might be Also had engine almost cut out.a few times after washing car.
Old Jan 31, 2014 | 10:14 AM
Pastor Blidberg's Avatar
GLK
I had this on my Car yeesterday, only on drivers side, it was approx. - 4 degr. Celcius and snowing, and i had washed my Car 2 hours earlier. I did move it out an in several times using the pushbutton on the doorpanel, and then it suddenly worked ok again. I guess it's a sensor for the working position that had got icecovered, or it need to bee properly adjusted reg. distanse to it's receiver, so it wont be so tender.
