2010 Headlamp Question and MODs
Old Mar 5, 2014 | 01:00 AM
ESBenz11's Avatar
E550 4MATIC,E350 4MATIC, E350, GLK350 4MATIC
Hell everyone, I have a 2010 GLK with the lighting package/ Intelligent lighting system. I've done a bit of research and I'm not the only one that has noticed this. When I start the car they adjust and they're a blue color… They seem to start off at 6000k. Within 30 seconds or less the HID Warms up and they go to 4300k a Yellowish white color… Mostly white… Anyway, is there a way I could have them always be that blueish/white color? Would I simply just replace the bulb to a different color temperature bulb? I don't know much about HIDS and Bi xenons ect…
Also…
I would like to replace the fogs and add aftermarket DRL's from ebay.
http://www.ebay.com/itm/Original-Size-Fog-Light-Replacement-to-Daylight-DRL-for-BENZ-GLK300-350-400-500-/111046626296?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AMercedes-Benz%7CModel%3AGLK350&hash=item19dae50bf8&vxp=mtrWould I have error codes or anything of that sort? Any complications?
Thinking about also installing running boards also from ebay.
http://www.ebay.com/itm/2010-13-Mercedes-Benz-GLK-GLK350-X204-Aluminum-Running-Board-Step-OE-AMG-Style-/121199729079?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AGLK350&hash=item1c381119b7&vxp=mtr
I've also been thinking about changing the interior lights to LED and the license plate lights but not sure if I'd get faults or anything of that sort.
Please educate me, I know very little about lights and wiring ect..
What are some MODS or Customizations you have done to your GLK? Post below!
Regards, Erik
Old Mar 5, 2014 | 01:47 AM
ble2716's Avatar
Very very slow
I have lightning package on my car too and I don't wana mess around with it.
As for running board, it's fairly straight forward to install.
Just remove the old one and bolt on new running boards.
It took me roughly about 2 hours, at easy pace.
Interior lights are fairly easy too, just be sure to buy a CANBUS type led bulbs or the lights stay dim when you're driving or stay dim after you lock your car for a long time.
As for license plate lights , I haven't change them so I can't comment on that.
Old Mar 5, 2014 | 02:07 AM
hondafan's Avatar
2008 Mercedes C300 4Matic Sport Sedan
Yes, you could absolutely replace only the bulbs if you wanted a bluer color once they've warmed up. I suggest using The Retrofit Source for your bulbs, personally, as the Morimoto bulbs are color accurate and reliable.
License plate bulbs are easy, and you just need to get CANBUS t10 LEDs. As for the interior, it's the same story. I swapped all of mine on my C300 and GLK too and they were identical for overhead lights.
You'll get an error on the DRLs without getting load resistors ("error cancellers"). The swap has been done, and some of them are very plug and play. You just lose your actual fog light function.
Old Mar 5, 2014 | 02:14 AM
ESBenz11's Avatar
How long did the interior lights take you?
Are you able to stand on running boards without a problem?
Old Mar 5, 2014 | 02:17 AM
ESBenz11's Avatar
Will the license plate and interior give me any error codes once swapped?
Also, how many wats do the Load Resistors have to be in order for it to operate correctly?
Old Mar 5, 2014 | 02:25 AM
ble2716's Avatar
Very very slow
You can stand on it no problem
It will be handy if you are going to load/unload stuff from the roof.
It's perfect for little kids, like 5 years old son.
For me, I like the look of it and hopefully it will protect some door dings from other cars.
It makes getting in and out of the car a little harder and soil your pants in winter time.
As for interior light bulbs, there's no error codes.
Old Mar 5, 2014 | 02:30 AM
ESBenz11's Avatar
Thank you. Extremely helpful.
Old Mar 5, 2014 | 09:50 AM
hondafan's Avatar
To add: The license plate lights won't give an error either. I had one burned out for probably a month before my wife noticed one night she was following me.
Time-wise, doing the interior lights takes all of 5 minutes. Use a panel popper or screwdriver and pull just the clear plastic down, pull out the old bulb (might be hot) and stick in the new one. If it doesn't light up, flip the bulb around and plug it back in again. Done. If you have the lights on the doors or under the dash, they all pop out easily as well. I had all of them, including the cargo area on the GLK replaced in a couple of minutes.
Also, how many watts do the Load Resistors have to be in order for it to operate correctly?
The factory W5WB bulbs draw 5 watts (or REALLY close like 4.8W), but if you search for CANBUS W5WB lights it should pull up LEDs with the right resistors already embedded in the chip.
Old Mar 5, 2014 | 11:27 AM
ESBenz11's Avatar
I'm talking about the load resistors for the fogs for installing the LED DRL.
So I'd use the CANBUS W5WB for all the interior and the license plates are CANBUS t10?
Old Mar 6, 2014 | 10:28 AM
hondafan's Avatar
Gotcha, sorry for the mix up. The factory fog lights draw 55W as the H11/H7 (both fit) setup. I'm not positive how much the factory LEDs draw, but I assume it's somewhere near 10W or so. I just found these on The Retrofit Source:
MORIMOTO HD LOAD RESISTORS
These are a total of 50W, so pairing them with any LEDs that draw 0-20W that should do the trick. If the LEDs draw more than 25W I would look for another solution. I'm happy to help find the right ones if you know what current the ones you want to install draw. Good luck.
