Front airbag service required/Pre-safe functions limited -- exact same time
Can anyone think of a reason why both would come on at the exact same time? Problem happened three times over a period of a few hours. The pre-safe I understand could be due to a dirty sensor (although the car is and has been clean), but it's suspicious to me that I'm getting that warning at the exact same time the front airbag service required.
I can clear out both messages by pressing OK, but the airbag light stays on until I stop the car. Starting up the next time, everything's OK again for 10-15 minutes.
Will be calling the dealer Monday morning, but figured I'd ask to see if anyone else has seen this before.
No wonder why nobody wants to mess with their car when it's still under warranty.
Even though the upgrade/mod were not even related to the cause.
Did you even ask the dealer if it is repairable? and how much it will cost?
If possible, ask for a written estimate.
- Get the part number(s) of the part(s) the dealer thinks are defective.
- Get a quote from the parts department at a different dealer.
- Determine where the sensor is located. If it's in the seat, I'd say the guy that did your ventilated seats should take some of the responsibility and help you out.
It is worth pointing out to your dealer that the Magnuson-Moss warranty act in your country provides you with a great deal of protection regarding warrantable issues. They cannot under any circumstance void your complete warranty. If any after market mods are interfering with the sensor, they have a case... if these are completely unrelated, they need to do the work.
Quite frankly, the dealer should want to do the work - warranty work pays better than regular work as they can bill shop time based on the prescribed warranty process, and normally most service folks can do the work a lot quicker than the shop times listed in service manuals.
Yes, modification of the front seat can impact the seat sensor, and in this case the factory wiring harness I "believe" will not have proper connections, so wiring to add that mod is outside/separate from MB wiring harness.
For the dealer - big time liability issue that frankly Mercedes will not allow the dealer to dive into.
In terms of "escalation," I'm thinking of proceeding in this way:
(1) I'll bring the car in (again, sadly, not for a while), and you can inspect all the connections, perhaps reconnect all the connections under the seat where they interface with the harness, and even unplug and plug the airbag sensor in again. I read one guy who had an older Mercedes that was having a problem like ours, and he simply disconnected the connector, blew into it, reconnected it, and the problem went away! That is, the issue could be as simple as there being a sufficiently poor connection somewhere that is causing the problem.
In this respect, today I'm going to shine a flashlight under the seat just to make sure that none of the wires look "crimped" or bent in a weird way. The one thing I'm having trouble figuring out is why this problem first manifested itself two weeks after having the seat work done. The only thing we could think of is that since the work has been done, the passenger seat wasn't moved after the first day until this past weekend -- Sherry took a friend out to dinner who moved the seat, and then when Sherry and I were driving the next day she moved the seat up and back. It wasn't until after that happened, when I was driving alone, that the problem first started. So I'm hoping (!) that perhaps the issue is as simply as the harness got stuck in a rail or something. I do know a few days beforehand when I was going through the car I saw some wiring harnesses, and pushed them back in.
(2) If this does not work, my next plan is to have you rewire the car back to "stock" in terms of the passenger seat. That is, you would disconnect the heating/ventilation controls from the passenger seat harness completely. Then, you would run new power lines, completely divorced from the seat harness, to power the heating/ventilation -- perhaps from the driver side harness, where there is no such occupancy sensor.
The idea here is that from an electrical perspective, there would be nothing different from the computer to the passenger seat than there was before the problem showed up. All the power for the heating/ventilation controls would come from a different harness/line. In theory, then, whatever electrical load (voltage, resistive, capacitive, inductive) that simply wiring the controls into the passenger harness would go away, and everything would work.
(3) Nevertheless, if this does not work, I have one last "hail mary" option. The thinking is that if (2) doesn't work, then the problem is that the physical addition of the heating and ventilation elements in the passenger seat itself is affecting the occupancy sensor, which is a resistive pad that changes electrical response in accordance with passenger weight. Third parties sell "occupancy sensor emulators." You disconnect the occupancy sensor, and connect the emulator in its place. This then tricks the computer into thinking that someone is always sitting in the passenger seat; you can't have a child seat or a dog in the passenger seat (although I'm openly wondering if some sort of switch could be connected inline), but it removes any interaction from the heating and ventilation elements with the occupancy sensor as a potential cause of this problem.
Apparently people buy such emulators primarily when they have older cars, and the occupancy sensors go bad. The sensors cost a lot, and this is a cheaper solution that still ensures proper airbag operation, with the downside noted above. Again, this is the hail mary option -- my preference would be not to have to go this route. I'm very much hoping that (1) will do the trick, and that we wouldn't have to proceed past (2).
In any case, after a passenger sat in the seat since the problem appeared, the problem has since gone away after multiple starts. Keeping my fingers crossed that it was just a strange gremlin issue.
