wheel and tire set ups
Old Nov 18, 2014 | 11:45 PM
reyrey11's Avatar
2012 mercedes benz glk350 4matic
Hi planning on changing my wheels and wanted to go 19x8.5 and wanted to go wider like 255/50/19. Just wanted to see you guys set up and pictures. Just want to get ideas from other x204 owners that change there wheels . Did any one ever change there wheels to the c63 or the e63 amg wheels ?
Old Nov 19, 2014 | 12:22 PM
Ben Conner's Avatar
Mercedes GLK 350
Been trying to do this for a month now. I have four replica AMG 19 x 8.5 wheels with a 45 mm offset. The rears will fit fine, however the fronts won't be able to fit due to the strut being so close to the tire. I have had to go with a 12mm hub centric spacer and will hopefully get them on this weekend after several tries with different wheels studs.
Here are the wheels I am putting on.
http://www.oemwheelplus.com/mercedes...ced-with-black
Old Nov 19, 2014 | 12:31 PM
kromdom's Avatar
2012 MB GLK350
Those are VERY sharp looking rims. Looking forward to pics after you have them mounted
Old Nov 19, 2014 | 12:34 PM
Ben Conner's Avatar
Mercedes GLK 350
Thanks, we have more of a base model mars red GLK. I though the black parts of the wheel would be just right with the black roof rails. I'll be happy just to get them on and be done with modding the wife's car. It wasn't supposed to be this difficult.
Old Nov 19, 2014 | 04:12 PM
reyrey11's Avatar
This is what im planning on getting for mine. You think if i go with a 35 offset would that fit on the fronts? I kinda want to stay away from spacers. And how wide of a tire are you going on?
https://mbworld.org/forums/attachments/wheels-tires-suspension-brakes-forum-sponsored-tire-rack/239464d1341856752-19-wr-05-mercedes-amg-c63-style-wheels-rims-7338h08_20.jpeg
Old Nov 19, 2014 | 04:48 PM
Ben Conner's Avatar
Mercedes GLK 350
https://mbworld.org/forums/attachmen...338h08_20.jpeg
Those look really nice. A 35 mm offset is going to move the wheel further in, not out, so I would stick with a 45mm. Im going with a 245 sized tire.
I wouldn't worry about the spacers, you just need to have the proper length studs. The whole "spacers are dangerous" comes from people putting them on cars and not lengthening the studs on the hub, this is turn causes less threads for seating the wheel on the hub and the possibility of a wheel coming off.
Of course the best thing to do is to get a wheel that is 8 inches or less in width. That just wasn't an option for me, it may not be for your as well. There is a possibility that the 4 matics are different, I just don't have any experience with that model.
Old Nov 19, 2014 | 09:26 PM
sterz85's Avatar
w205 C43, 958.1 CTT
where are you guys getting your rims from?
I'm thinking about getting these guys
http://www.powerwheelspro.com/shop/p...roducts_id=615
Old Nov 24, 2014 | 02:15 PM
Ben Conner's Avatar
Mercedes GLK 350
Those are going to be way to wide for your vehicle and will not fit. They look great otherwise.
Old Nov 24, 2014 | 02:27 PM
buckeyesoldier's Avatar
glk250
These look sweet, I was thinking about getting the same ones. Can you please post pics once you have them on and let us know about the ride/handling experience with the new wheels. Thanks!!!
Old Nov 24, 2014 | 03:08 PM
sterz85's Avatar
w205 C43, 958.1 CTT
20x9's should fit fine on the car
still debating when i want to do this because of how crappy the michigan roads get after the winter is over
Old Nov 25, 2014 | 12:04 PM
Ben Conner's Avatar
Mercedes GLK 350
A 9 inch wheel up front with a 35mm offset maybe, but probably not. I had an 8.5 with a 45mm offset with barely any room left, if any, between the strut and the wheel.
