06 E63 AMG front brakes: practically a bolt on
Old Feb 28, 2015 | 02:04 PM
Djorge's Avatar
GLK 220 CDI Sport
Just to report that today I confirmed that a front brake set from the older E63 , 06 w/ AMG 8 pot brembos & 350 rotors are doable with just minor spacer to adjust the offset to center calipers to rotors, really few mm - have 19" CLC 5 spoke replica rims with plenty offset so not sure if 18" will clear too - will cut the heavy OEM rotors to put lither aluminum hats, probably slot them too - this week will test fit the rear AMG 4 pot calipers, maybe also lucky with same fittings and no need of any major fabrications, new brackets like some C63 kit, fir those interested - pictures soon!
Old Mar 3, 2015 | 01:48 PM
Gotti78's Avatar
08 C350
Cant wait to see.
Old Mar 3, 2015 | 05:55 PM
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
Yes, pics!
Old Apr 4, 2015 | 11:28 PM
Djorge's Avatar
GLK 220 CDI Sport
Front and rears done
So the result is: front 8 pot calipers from E63, fitted with 4 mm spacers and E63 rotors, used the GLks bolts with plenty of thread - rear 4 pot calipers from same E63 also fitted to OeMs bolt holes, but required a 7mm spacer to match GLks oem rotors, still smaller in diam - to avoid cutting them pulled the GLKs front dust shields, need a full front and rear set from any E63 AMG while the worst will be finding crrect AMG rear rotors! Still, I need to find a set of the front 8 pot calipers springs (pictured example) - Posting pics
Attached Thumbnails 06 E63 AMG front brakes: practically a bolt on-image.jpg
Old Apr 4, 2015 | 11:35 PM
Djorge's Avatar
GLK 220 CDI Sport
Old Apr 4, 2015 | 11:36 PM
Djorge's Avatar
GLK 220 CDI Sport
Old Apr 4, 2015 | 11:38 PM
Djorge's Avatar
GLK 220 CDI Sport
Old Apr 7, 2015 | 11:18 PM
Mr. JLT's Avatar
To many to list
Try putting the front rotors on the rear and see how they work. You may have to make an adapter so the caliper clears the bigger rotors. That's what I've done on a few BBK's I've built. I'll look through some cad files I have. If not I can build a new cad file and cut some adapters when I get some free time.
Old Apr 7, 2015 | 11:37 PM
MBKLUE's Avatar
Yikes:
Originally Posted by Mr. JLT
Try putting the front rotors on the rear and see how they work. You may have to make an adapter so the caliper clears the bigger diameter rotors. That's what I've done on a few BBK's I've built.
And make sure your Life Insurance policy is up to date.
Old Apr 7, 2015 | 11:45 PM
Mr. JLT's Avatar
To many to list
Don't worry it is, if your not interested in the BBK thread just move along.
Old Apr 7, 2015 | 11:48 PM
MBKLUE's Avatar
Yikes:
Thanks, but I'll pass on your suggestion. I don't mind if you drive off a cliff (as long as you don't hurt a mountain goat on the way down) but there are other road users that can get injured or worse by "not smart things" being done by some people.
Old Apr 8, 2015 | 12:12 AM
Mr. JLT's Avatar
To many to list
06 E63 AMG front brakes: practically a bolt on-pb040124.jpg
06 E63 AMG front brakes: practically a bolt on-cdbaca8a.jpg
06 E63 AMG front brakes: practically a bolt on-8cd1fa45.jpg
06 E63 AMG front brakes: practically a bolt on-hrebrembo.jpg
06 E63 AMG front brakes: practically a bolt on-854926a4.jpg
06 E63 AMG front brakes: practically a bolt on-b32a21ca-fd23-40cf-a869-482179cc97bf_zpslsgbtths.jpg
Old Apr 8, 2015 | 12:18 AM
Mr. JLT's Avatar
To many to list
I don't have time to argue with you. If you don't have any info to add to the thread keep moving. Feel free to Pm me if you like.
Old Apr 8, 2015 | 12:28 AM
MBKLUE's Avatar
Yikes:
Am I meant to be impressed by the photos you posted? I am not.
I did/do have something to add to this thread. Be very careful messing around with a well-engineered brake system and brake balance.
No, I do not care to PM you and do not tell me to "keep moving." Understood? Is that clear?
Old Apr 8, 2015 | 12:50 AM
Mr. JLT's Avatar
To many to list
Ok I'm over this guy.
Djorge I have a few companies that already have two piece rotors. Chris can change the offset in the hats so the spacers may not be required for centering the calipers.
Old Apr 8, 2015 | 12:56 AM
MBKLUE's Avatar
Yikes:
Ok I'm over this guy. ...
and I wasn't even aware we were in a relationship...
Old Apr 8, 2015 | 06:54 AM
NYCGLK's Avatar
GLK 350 / Porsche 993
This is cool, but I have a couple questions:
Are the points where calipers attach strong enough for the increased breaking forces?
Does ESP or ABS need to be reprogrammed?
How much do AMG calipers run for? Seems like a bit of a waste, to put them on GLK.
It's good to see somebody trying things like that. When is the 6.2 litter motor going in?
Old Jun 1, 2015 | 06:38 AM
Djorge's Avatar
GLK 220 CDI Sport
AMG brakes - all set to GLK
This weekend finished the set up w/ the rear rotors (CLS63 07-11, E63 07-09, E55 03-06, CLS55 06) - bought the drilled Meyle pair from ebay http://www.ebay.com/itm/351233203608?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT and the surprise - the rear calipers no longer need the spacers used when fitted to the smaller GLK's rotors, real direct bolt on - so conclusions are that only the 7 mm front spacers are needed to fit the front 8 piston calipers to any 2009-13 GLK (maybe same for other M/Ys) besides taking out the front dust shields which are smaller diameter and do not have enough cut outs for the larger calipers;
Old Jun 1, 2015 | 06:48 AM
Djorge's Avatar
GLK 220 CDI Sport
Hey there, measured the caliper fittings and they're exactly same thickness as the E63/CLS so, no brainer though - nothing to reprogram thus far (no error codes, I meant) but intend to have the car at 30,000 km service this week or next and check it all - bought these calipers real cheap 2nd hand from a wrecked car, the new front heavy OEM rotors costed more, trust me - only regret are the fronts' unsprung weight by those rotors, but nothing that affected its already poor mileage - running smaller tires (255/45 and 275/40) helped a lot, cause here in Brazil we don't find the OEM 19s beyond just 2 brands/versions (Pzeros and Contis);
Old Jun 1, 2015 | 06:50 AM
Djorge's Avatar
GLK 220 CDI Sport
2 pc rotors
Hey JLT, can you pass me those contacts? really wanted to reduce the fronts, too heavy rotors, despite the 8 pot calipers are way lighter than the original set; Cheers!
