Water Dripping
Old Nov 3, 2015 | 10:36 PM
Mystic2k's Avatar
2011 GLK 350
Water Dripping
I have used automatic car wash for many times. But today after the car wash, I heard dripping sound and found water on the front passenger plastic floor mat. I could feel the panel under the glove box was wet as well.
Was it because this particular car wash machine sprayed too much water so it went through the HVAC system?
Is it something getting aged?
Anybody had the same experience? Thank you!
Old Nov 4, 2015 | 02:37 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
two things:
1. check to see if the cowl below the windshield has leaves blocking the drain slots
2. I think there is something on the manual (or read somewhere on this thread) that whenever you are using a automated car wash to make sure to turn the air flow to recirculating mode so that the intake will close and will prevent water from coming in.
Get that dried asap as you do not want any rusting or worst molds growing inside your car.
Old Nov 4, 2015 | 02:58 AM
Mystic2k's Avatar
2011 GLK 350
Thank you!
You just remind me that I used to turn off the HVAC when using automated car wash but not this time. That might solve the problem.
But just kind of curious that will pouring rain have the same effect? or it's because high pressure from car wash?
Old Nov 4, 2015 | 02:44 PM
bop11's Avatar
350 GLK, C280
You heard it dripping so did you see where it came from?
Old Nov 4, 2015 | 10:53 PM
Mystic2k's Avatar
2011 GLK 350
By the time I stopped the car and check the sound, there was no more dripping.
But when I touched the panel under glove box where the cabin filter located, I could feel it's wet.
The water must get inside through the HVAC air intake.
Old Nov 6, 2015 | 05:41 PM
TPete19's Avatar
2010 C63 AMG, 2010 GLK350
The other common cause of this issue is a clogged/disconnected drain from the moon-roof system. That will require either dropping the headliner and checking them yourself, or a visit to the dealer to do it.
Old Nov 7, 2015 | 02:05 AM
Must be the pressure of the car wash as regular rain or even a house hose will not easily get the water into the hvac opening unless you really jam it on the opening. There is a car wash shop here in Canada that before they let you inside the carwash the carwash boy tapes a small plastic on the cowl where the HVAC opening is just to make sure water won't go in and not hassle the owner of the car to press the recirculation button which most of the time the driver does not know what and where that button is.
TPete19 is also correct as you may also have a clogged or disconnected moon-roof drain and the only way to find out is to get a garden hose and hose down the entire moon roof section by section and see if you will have water dripping inside there but from how you described it my bet is water came inside the hvac opening.
If it indeed came inside the hvac opening I would suggest to take out your cabin air filter and check if it is wet. If it is wet then water did came from the hvac opening and you
MUST replace that filter (or make sure it is 100% dry) or else mold might grow there. Also run your fan to high for 20-30 minutes to dry out the ducts.
I once have a Cadillac Catera which have a very poor hvac intake design that if there is a small debris on top of the opening you will have a flood inside your car. One time I have a ice skating rink inside the front passenger floor as we had a nasty winter rain in the evening then came midnight temperature went to -2 and froze the water inside. Took me the entire day to let it thaw and vacuum out the water little by little.
Old Nov 8, 2015 | 02:14 PM
Mystic2k's Avatar
2011 GLK 350
shotgun_banjo, thanks for the info.
Luckily I haven't replaced the cabin air filter yet. It's time to replace now.
TPete19, I think the clogged moonroof isn't likely. I live in rainy city, all day rain. I don't see the same symptom. Thanks.
I'll try the car wash again with HVAC off next week. The new 24hr car wash is offering free car wash for November.
Old Nov 10, 2015 | 02:00 PM
Free November car wash....same here in Vancouver. Where are you located?
Old Nov 10, 2015 | 02:11 PM
Mystic2k's Avatar
2011 GLK 350
Burnaby!! We are neighbours!
Just an update, after 30mins long wait for car wash with HVAC off yesterday, I didn't notice any water dripping. I didn't switch to circulation. Perhaps the water can get in but not that much to cause dripping. This car wash tunnel is twice longer than the one I used to go.
