GLK350 Sprark Plugs - DIY
Old Apr 12, 2025 | 08:00 PM
  #51
W205C43PFL's Avatar
Originally Posted by SAVZ
Did not use anti seize last time, no problems getting them out this time. Only thing that got stuck was the rubber grommet from socket on the first plug I changed and torqued down. I think just from age, but for the rest I bought a new magnetic socket plug. I actually tried putting the coil back on and was wondering why it wasn’t going in all the way, when I took out the coil the rubber insert was sitting inside the coil boot, and I pulled it out easily. Honestly if I realized the grommet was left behind before putting the coil back on, I probably would have had to remove the new plug. You can kind of see the rubber grommet around the plug in the picture attached.
Old Apr 12, 2025 | 08:07 PM
  #52
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
After all this time, I just noticed the title says Sprark instead of Spark.
Old Apr 12, 2025 | 08:58 PM
  #53
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Typical side effect of the NJ accent. 🙂
