2010 Glk 350 cranks, no start
2010 Mercedes glk 350
While I just got a cam sensor error, my car cranked continuously, but failed to turn over and start. Battery is good.
Has 80,000.
Anyone real knowledgeable on an intermittent starting problem ?
Is replacing the cam sensor something that you would say a general beginning mechanic can do himself? I have removed a valve cover from a Honda and vw, but not Mercedes. Are special tools required or any particulars likely needed?
Has 80,000.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
With your limited experience you will do just great(no special tools)----just don't fall into the cheap aftermarket parts syndrome---use an OEM part in this instance!!
