2010 glk 350- parking leds
2010 Mercedes glk 350
I have spent 15 minutes reading through threads with no direct response to know for sure if i can replace the parking lights with a simple led replacement bulb.
Does anyone actually know if a resistor is needed or it can be done at all. I do have some cheap chinese led's that i got off ebay but sure wouldn't want to cause any check engine codes.
I just want to spend a few dollars so i can sit in my car longer with the radio on.
SPONSOR/MBworld Guru
You'll need canbus LEDs, not regular LEDs. Should be 194 wedge LEDs for your parking lights. Let us know if we can help.
2010 glk350
I installed an led to replace the standard bulb in the eyebrow or eyelid light above my headlight. It worked on one side, but not on the other. Now i put regular bulb back and it doesn't work at all. Anyone know what is happening?
