engine mounts
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
I replaced all 3 motor mounts (2 front and transmission) in December 2013. Only 24,000 miles on the odometer since the replacement. I have learned that I need to replace them again. I have no doubt about the competency or honesty of the mechanic. He said that he was not surprised and that it was highly unlikely that it had anything to do with my driving.
Has anyone else experienced such a short life for your motor mounts. I have a 2004 E55 AMG with 101,000 miles. It has an R1 RennTech package (if that has any bearing on this issue, which does not seem likely)
The dealer quoted me almost $1,800, most of which is labor, and won't pitch in on the cost at all.
I will probably just do them myself since it doesn't look like too bad a job.
I have read too many accounts of this for it to be anything other than poor engineering.
The Best or Nothing my a$$...
truax (09-25-2020)
Following up on this as promised. We just completed installing new mounts on 2010 GLK350. The truck had about 85,000 miles on it, was exhibiting vibrations in brake pedal, head rests, and steering wheel mainly while stopped at traffic lights. New mounts totally solved the problem, the truck is back to being buttery smooth again. The dealer quoted us 9 hours of labor and $2000 for this job. So we bought the mounts from FCP Euro and got to it. It took us 10 hours. If we had to do it again we could probably shave off 2 hours. This job is not particularly difficult or complex, but the time needed simply comes down to lack of space and lack of access. Creativity will be needed for extensions, universals and using 1/4" tools in tight spots. The youtube tool thing was pretty handy but it's small in the overall scope of the job.
Removing the axles is straight forward, I was anticipating this to be worse than it actually was, it's very easy. We had no luck using a pry bar to disconnect the axles, wasnt much to pry on. We used a 5 pound slide hammer and a chain wrapped behind the inside 'can' of the axle. If the chain is too thick it wont fit through the frame. We used a #2/0 sized chain, I wouldn't use anything larger than that. Unbolt the axle bolt (one time use) at the hub and remove the axle from the hub. To give you room to maneuver the axle out, the hub should be disconnected off the shock mount, and lowered down out of the way, it's helpful to have extra set of hands. The slide hammer and chain should be as horizontal as possible, it will only take one tug to pop the axle right out. Re-Installing the axle is easy, it will pop in with a resounding snap when the circlip catches. The circlips should also be replaced (we did not).
I don't think the passenger side axle needs to be removed, although we removed it. With the alternator unbolted from the engine (4 bolts pointing towards the passenger fender), there is plenty of room to maneuver the passenger side mount out of the vehicle. In order to get the drivers side mount out, after its free, the passenger side needs to be out first to allow the engine more freedom to be moved around. We removed the axle on the drivers side, then disconnected the steering shaft near the axle. Steering disconnect is pretty straight forward. Just a bolt and sliding the sleeve out of the way. The steering shaft is keyed. This, in combination with moving the motor up/down allowed the drivers mount to be removed from the vehicle (after it was unbolted). It's not hard to unbolt them, just tricky to get them out. Unbolting them first is pretty quick affair. The balance of the time will be spent maneuvering the free mount out of the compartment, fidgeting with the two heat shields.
Collapsed mount on right.
the tool used for the center mount bolt.
cashalot (02-04-2021)
B737 (01-01-2020)
#39
GLK350 2010 Sold C63 AMG 2012 Sedan Sold GLK250 2013
The reason i asked if it affects the 250 is that the engine is significantly smaller than the one on the 350. So i was guessing its not compressing the mounts as much. Anyone out there with a GLK250 that had to replace their mounts.
#40
That's an interesting point. I think the weight is difference is not the biggest factor with the transmission attached, but the problem on 350 is that the exhaust manifolds run right next to the mounts. I think the heat is what kills them so quickly. On the diesel, it might be a different arrangement. And yes fair point that on 250 there are probably a lot more space to work with.
#42
2009 C300 Sport Palladium Silver & 2012 GLK350 4matic Black
Which motor mount from FCP Euro?
Did you get the Lemforder motor mount from FCP Euro? https://www.fcpeuro.com/products/mer...unt-2042402017
or the Genuine MB motor mount? https://www.fcpeuro.com/products/mer...mer-2042402017
Also, how many miles since replaced?
#44
#45
#46
