P0015 Code Cam Position Timing
Old Dec 16, 2016 | 07:07 PM
Rascally Wabbit's Avatar
2010 Mercedes GLK 350, 2001 BMW Z3 3.0 Roadster, 1997 Cherokee XJ
Intermittent CEL caused by P0015 code, camshaft position timing. MB has or had a campaign on this & ours was performed in 2014. Here is a link to the details.
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=177389
From researching, earlier MB models, especially the "C" class have had the most problem. Affects the GLK350 through the 2012 models when the new engine was introduced. Has anyone else experienced such a problem? TIA!
Old Dec 16, 2016 | 07:22 PM
ItalianJoe1's Avatar
2003 CL 600
The campaign is only to add a harness extension at the cam sensors. If your car is elegible, the dealer will do that for free and fix any damage caused by the oil intrusion if it has caused a CEL.
It's more likely, you have an issue with the cam magnet itself or the timing gear, or you have a timing issue in the engine itself.
