Diamond Sport grille ? Anyone ?
#102
So once you get your grille take a good look on the back of the mounting points at the bottom and install the emblem of your choice.
You will need a few tools:
-prybars
-10mm socket
-A swivel extension helps the nut removing
1.) Deactivate the engine and release the bonnet
2.) Remove the engine bay seal from the plastic cover. it simply lifts upward and pull it aside.
-prybars
-10mm socket
#104
Hi there, has anyone succeeded on fitting this single blade grill to an older GLK (2010-12)? I'd really like to make it w/ the diamond pattern + single blade, still hesitating to try it ---
Jack Armour (09-13-2019)
Benzordie (07-02-2020)
#106
2010 Glk350
#108
#109
diamond style grille for Glk 250 with 360 cam
Hello everyone. i am new to the forum and i just got a 2014 Glk 250. and im thinking of getting the aftermarket sports grille. The problem is i cant seem to find a version with the front camera attached.
does anyone have a solution or work around? i really like the look of the sports grille.
thanks!
thanks!
