New owner; 2 questions
Old Mar 12, 2017 | 10:42 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Hey guys,
i am very new to the m276 engine...that being said I have started to hear a constant buzzing sound when I drive the car coming from the engine. I do have very distinct hearing (former Morse code operator) but I've asked others and they hear it too. Is this a thing amongst the DI engine? Is it normal? No codes at all vehicle is a 2015 with 51k miles (just over warranty so I don't want to take it in) I tried a search and couldn't really find anything
also the vents will randomly tick. Not constant and not the same one, each one will just randomly tick and I get maybe one tick every several seconds
thanks guys and gals!
Old Mar 13, 2017 | 07:04 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
https://youtu.be/ekinJQjSksY
here is a video of the noise. Is this normal?
Old Mar 13, 2017 | 07:52 PM
Hugo L.'s Avatar
2014 GLK250
Dude, my diesel clatters less than that.
No idea what it is though, sounds external to the engine. One of the ancillaries going bad perhaps?
Old Mar 14, 2017 | 01:00 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Dealer service manager said it was definitely poor fuel...the previous owner(female in her early 30s) admitted to using both cheap and premium gas because her mechanic said it was ok...I'm going to run out the gas in it out some fuel system cleaner and fill it up. Also going to do an oil change. Hope this helps it
Old Mar 14, 2017 | 01:15 PM
Hugo L.'s Avatar
2014 GLK250
That can't be good in the long run!
Old Mar 15, 2017 | 12:46 AM
Trixstar's Avatar
2014 GLK 350
Hi there, my 2013 GLK350 with the same engine also has that ticking noise. It's a very similar sound. The mechanic said it's because of the lifters. No big concern. My vents also has a tick sound from time to time.
It's much better after I bought these. They are attached to the vent and help to make it more snug so that it doesnt move around as you drive.
https://m.aliexpress.com/s/item/32512575670.html
Good luck!
Old Mar 15, 2017 | 10:52 AM
Mmr1's Avatar
2013 glk 350
I can't access the video.
Direct injection is more noisy. Is it a new noise? Alcohol will help a batch of bad gas , it absorbes water and raises the octane. products like Heat are alcohol and sold at most gas stations, for bad gas you might need 3-5 cans of it.
A mechanic said it's bad gas? And what if it doesn't change with good gas?
Does it sound the same idling and accelerating?
Old Mar 15, 2017 | 12:37 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
thanks for the replies,
The service manager said it can get better over time, but due to the amunt of miles (51k) he recommenced I do an oil change (which im going to do anyway) and throw in some fuel system cleaner in it and fill with premium...hope this will help it. I will keep everyone posted, will do by the end of the week
Old Mar 15, 2017 | 07:17 PM
Hugo L.'s Avatar
2014 GLK250
Seafoam the hell out of it too.
Old Mar 16, 2017 | 09:25 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Took the car to the dealer for the noise again, and to get an oil change. Tech said that there is a buzzing noise that is likely coming from the high pressure fuel pump-1400 estimate for the fix. I called MBUSA and a case manager is going to call me back to see if they will be able to help me out as I'm at 51.5k miles. Will keep everyone posted. Does anyone know where the fuel filter and the fuel pump is located on this car? I've looked online and didn't find a definite answer, I'm assuming it's inside the fuel tank? Anyone have a diagram or DIY or anything related? I figure I'll change out the filter and pump regardless. Thanks for the help
Old Mar 17, 2017 | 07:22 PM
Mmr1's Avatar
2013 glk 350
Still can't hear the sound.
Old Mar 17, 2017 | 07:32 PM
Mmr1's Avatar
2013 glk 350
I believe there is a chain ,startup , lack of oil lubrication issue, which nobody wants to admit
And I have repair info on ! .
Old Mar 17, 2017 | 08:54 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
You can copy and paste my YouTube link in your browser...send me the repair info that you are referring to. I am not having any start up noise at all, this is a constant noise.
I am also just for preventative maintenance doing a coolant flush, air filter, and fuel filter (mainly because previous owner ran 87)
Still waiting for the fuel pump issue with MBUSA...it's only a slight buzzing sound but I just hate noises, it doesn't bother my gf at all she can't even hear it
Old Mar 28, 2017 | 05:41 PM
mjhawkins2346's Avatar
2016 GLE300d 4Matic
The other blog had someone digging into the tank for the filter. It's under the back seat under one of the two access plates for the tank. He posted a bunch of PDF's that impressed me with the complexity but it didn't seem impossible. I sure would rule out other things first though.
Old Mar 28, 2017 | 09:09 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Ordered all the parts along with some oem running boards...going to do it all this sunday with the help of a forum member on here. He has his own shop in Maryland and does great work.
MBUSA offered me 15% off the fuel pump...in going to have my guy diagnose it further and if it just the sound I'll deal with it for now, not worth paying 1000$ for some noise. I will keep everyone updated
Old Apr 4, 2017 | 06:49 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Ended up doing the fuel filter, coolant flush, and engine air filter (omg that air filter was disgusting)
im now getting over 24 mpg averaging 31mph mixed city and highway
the eco mode actually engages now!!!
car sounds about the same maybe a little quieter, it is definitely coming from the injectors though and don't think any issue with the high pressure fuel pump.
Old Apr 4, 2017 | 06:56 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Here are some photos
Old Apr 5, 2017 | 10:53 AM
Mmr1's Avatar
2013 glk 350
Is it under warranty
Old Apr 5, 2017 | 09:59 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
No it now has 52k miles out
Old Apr 7, 2017 | 07:21 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Finally took some quick shots after mounting the new rims...
Old Apr 7, 2017 | 08:52 PM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
nice!
Old Apr 9, 2017 | 10:54 PM
Jett's Avatar
I drive an '11 C300 and wife drives an '11 GLK350
looks great!
Old Apr 10, 2017 | 01:36 PM
Dan M's Avatar
2013 GLK350
Looks great. Where did you find the wheels? I've been looking for a set.
Thanks, Dan
Old Apr 10, 2017 | 06:52 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
Found them them on eBay. Oem freshly powder coated
Thanks, Dan
