GLK adjusting height of xenon auto steering headligts
Folks, I have a 2013 GLK250 with the xenon steering headlamps. Before we bought the car, it was in a minor front fender bender. No problem, except that the right headlight is too high. I need to adjust it. Both move fine, but the right one's "home" position needs to be adjusted. Does anyone have instructions / pictures? I'd appreciate it.
Thanks,
Thanks,
slmskrs (03-20-2017)
If it is like my previous CLK or E500 then you just adjust the headlight like normal on level ground, you are basically setting the starting point for the auto adjustment and it will reset back to where you set it after it does it's job. Basically nothing special.
Thanks.
[QUOTE=AzCamel;7089682]Yes, there is a level and adjustment via screw driver[/QUOTE
Found the screw (torx) and moved it. Will need to wait until this evening to project onto the garage door and see if it's fixed. But thank you!!
Gordon
Gordon
