Brake bleeding question
Old Mar 25, 2017 | 05:33 PM
whiskywizard's Avatar
2011 Porsche 997.2, 2015 GLK250, 2009 Sierra 2500HD Diesel
Has anyone here flushed brake fluid on a 2015 GLK? Any issue using a vacuum instead of pressure?
I completed most of the B0 service today on my wife's 2015 GLK250. Oil, filter, cabin filter, air filter, checked fluids, added DEF. I still need to change brake fluid, and I'll do that in a week or 2 when I take off the snow tires.
I have both a Motive pressure bleeder and vacuum pump but generally prefer vacuum as there less chance of a leak spraying brake fluid around under pressure.
Comments?
Old Mar 27, 2017 | 07:24 PM
SAVZ's Avatar
2010 GLK350 4matic
I did it with the mityvac vacuum, it took a while to do it this way, fluid was flowing very slow, i think next time im going to use pressure. Plus the old fluid looked almost identical to the new (both MB fluid), I think a different color fluid would have made think much easier too.
Old Mar 28, 2017 | 07:44 AM
Thanks SAVZ. I did the job yesterday, using my Motive pressure pump. No issues encountered.
I agree about the colour difference, or lack of difference. The wife's GLK is about 22 mo old, and 55,000km so the old brake fluid still looked like new. I miss the old ATE Super Blue brake fluid. Alternating between the Super Blue and the regular amber Typ 200 really showed clearly when you'd pushed the old fluid through with new.
Old Sep 2, 2023 | 02:08 PM
uniplexed's Avatar
2013 GLK250 Bluetec & 2014 E550 Cabriolet
I remember that I have read a post in somewhere (can't find it now) that newer MB models need Xentry (or MB-specific OBD II scanner) to command car computer to flush the whole brake fluid. Is it true? Mine is 2013 GLK250 and thinking to bleed it soon and wondering if the old school method would be okay with it.
Old Sep 2, 2023 | 04:05 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
To bleed the system after something like a caliper change, you should be able to do it the "conventional" way. If you want to flush the system of all old fluid you need to be able to trigger the ABS system.
Old Sep 2, 2023 | 05:21 PM
Mmr1's Avatar
2013 glk 350
How do I trigger the ABS system in my garage with hand tools and no experience?
Old Sep 2, 2023 | 06:34 PM
uniplexed's Avatar
Or... would this work?
Old Sep 2, 2023 | 07:32 PM
John CC's Avatar
No way that I know of. You need a software package that will activate the ABS pump. Otherwise the fluid in the ABS system stays trapped in there and cannot be exchanges with the rest of the system.
No, that's just to make it easier for one person to bleed the brakes. It doesn't activate the ABS system.
Old Sep 2, 2023 | 07:45 PM
Mmr1's Avatar
2013 glk 350
So with a regular brake fluid flush, the fluid in the abs never gets changed , or circulates ? It stays old ?
Old Sep 2, 2023 | 08:14 PM
John CC's Avatar
It circulates if the ABS gets activated, and gradually mixes with the new fluid, so it's not a total loss.
Old Sep 2, 2023 | 08:37 PM
uniplexed's Avatar
Hmm that sounds like we should go to dealership service or MB-specialized shop for brake bleeding… like for changing transmission oil? I don’t think that local brake/muffler shop would follow the right process for ABS (or even don’t have a device to activate ABS).
Old Sep 2, 2023 | 08:56 PM
Mmr1's Avatar
2013 glk 350
Do abs modules fail often?
Old Sep 2, 2023 | 10:15 PM
John CC's Avatar
No, not that I am aware of.
Don't confuse bleeding, which is unchanged from the advent of hydraulic brakes, with flushing or changing the fluid. To get all the old fluid out you need a way to activate the ABS module. I should think that any independent business that services Mercedes on a regular basis would be able to do this. Also, I would expect at least some of these DIY scanner systems could also do it.
Old Sep 3, 2023 | 12:18 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Mid level scanners with 2way communication (not just code reset requests) within the price range of DIYers can access the ABS controls. Code readers, even if they can see ABS codes, cannot. If you intend to do your own trouble shooting and repairs, it might be worth the cost, and be certain ABS control is specified in the description. If not, find an independent familiar with Mercedes to do it.
Old Sep 3, 2023 | 08:21 AM
Mmr1's Avatar
2013 glk 350
Is the abs the same system that controls , Traction Control? If so then in snow, when it activates , would it circulate in any new fluid?
Old Sep 3, 2023 | 03:44 PM
John CC's Avatar
Traction control utilizes ABS, and yes, if it activates that will circulate the fluid. If you have snow and/or ice available you can activate it yourself...
