New to Diesel, Glk250 EGR/DPF Delete?
Ive read about common problems people experienced, and Id like remove the egr/dpf system completely. Since it'll save my engine from unnecessary soot buildup, while increasing MPG. Also saving a few hundred in long term adblue refills wont hurt.
I hear its illegal, but I don't need to get emissions checks in my situation.
after hours of research on the these forums, I see you can "turn off" the egr/dpf system through ECU reprogramming but is a physical delete recommended?
And if so who has done it or have the know-how?
It could be a real can of worms otherwise
There may be a problem with resale later
I cant see the advantage of a delete unless or until you are faced with a component failure
I read on the diesel forum about a guy with his bluetechGL opening his manifold to find caked up residue from years of use and regular maintenance.
That drained some of his power and efficiency.
id like to avoid that seemingly inevitable fate, assuming the process is relatively safe/easy.
But Youre right, I would never do it under warranty
Of course I wouldnt be doing it anytime soon, im still under warranty.
doing so now would certainly void it.
I dont know how diesel laws are in Norway, but the U.S is quite strict. much of europe embraces diesels, I dont see any reports of how bad their air is
But anyways, why wouldnt you want to get better performance from your vehicle??
Doing this delete/injection mod after the warranty expires is generally too late. if you can't do deletes, change the oil more often.
