Purchase advice
I am considering the purchase of a GLK350 4Matic. I don't want a diesel. The external angular styling I love and the MB brand, and 4Matic capability is what draws me to this vehicle. I tend to like the first generation but not apposed to either styling. I test drove one and like it. I'm looking for a low mileage example and will most likely keep it for many years. I'm one who is very diligent on regular detailing and maintenance of my vehicles. It will be garage kept when not in use. Will be used for daily city commuting rain and occasional snow in winter. This will be my first Mercedes Benz.
Please tell me from your buying and ownership experience:
What are the better years?
What is its Achilles heel or its issues?
How has reliability and maintenance cost been?
How is durability and longevity?
What do you like and dislike?
Thank you for the help.
The GLK has a very good track record for reliability. Not over complicated like the newer Mercedes and not bland like a BMW. I see at least 10 on commute everyday in Los Angeles.
You can see the preconditions as outlined by Daimler here
I do have one very important question. I'm sure throughout the ages it been asked ad nauseam, but none the less, it is an important first MB purchase consideration. This is maintenance costs.
The consensus out there from owner experience seems to illustrate that they are a wallet wringer. But I can't seem to get a straight answer as to WHY?
I researched parts and the majority don't seem that outrageously expensive. The only other variable must be labor rates. Even then, my best ASE certified mechanic charges a typical $90 hour. That should equate to similar repair costs of other cars.
Do MB break more often than other brands? if so, that by frequency alone would attribute to higher costs.
Am I missing something here?
Every single GLK in America and Canada are assembled in Germany using a majority German, Austrian and other European parts. The fluids and fuel we use are higher performance.
To compare, the genuine oil filter is made in France by Purflux; whereas my genuine Toyota oil filter is made in Thailand. The Mercedes oil filter cost 4 times as much, but is constructed to be more durable with a larger filtering area.
If you break the LED HID lights, that is well over a thousand for the entire single housing. If you need a front bumper that is like $700. Part of the cost is that you are paying for someone to hold an obsolete part in warehouse for XX amount of time.
The GLK is simple. No unnecessary luxury features like air suspension, soft close doors, more horsepower than the average person can handle, night vision camera, electronic parking brake, and etc. Many things can be done by yourself like fluid changes, air filter changes, tire rotation, and brake pads.
So Premium Car uses premium parts, which demands premium prices.
I've had two people personally tell me their Mercedes (not GLK's) have been mostly trouble-free outside the basics - fluids, filters, belts, hoses, plugs, wires, etc.
MB is known for it's superior ride. How long should the suspension components last to maintain the integrity of ride comfort/quality before major parts need to be replaced?
- some 722 transmissions are known to grenade. they typically start whining before they do. test drive accordingly. transmission service is 4 years 40,000 miles you can DIY or have dealer do it ~$800. Servicing the transmission is thought to be critical regarding premature failure.
- ESL / EIS failures, typically after 6-8 years, render vehicle immobile. ~$1000 each at dealer or DIY by mailing your keys and module out to someone specializing in this (cant use your vehicle while this is going on).
- common for brakes on these trucks to squeak / squeal if not serviced properly.
- in 2013+ they went to direct injection (use your own judgment here)
- thoroughly inspect Bluetooth connectivity, you may be in for a surprise to stream music from you cell phone ect
- try to find a truck with MMP / technology package so you get rear view camera ect
- leaks from transmission are also common and very expensive to repair, typically the seal in the back of the tranny (not the pan).
- automatic steering wheel height adjustment frequently breaks / broken. PITA cheap DIY or another ~$800 trip to dealer.
- keyless go, while "cool" is super expensive to trouble shoot and repair when it breaks, also a difficult DIY.
- sunroof sync issues, or sunshade operational issues are common but usually not a big deal
- Engine mounts are a common failure before 100,000 miles, the 4matic engine mounts are time intensive and tricky to replace. 2wd are much easier with the right tools.
- Thermostat getting stuck open, CEL for code P0128 is common between 40,000-100,000 miles. $600 trip to dealer or about $150 in parts if you do it yourself.
do thorough test drive, due diligence, drive a lot of them to get a feel for whats wrong and whats not. dont forget to check for all the things you would normally look for on any used vehicle (oil coolant AC ect).
im sure im missing some, if you search there is a lot of info about this on the forum, also look at W204 subsection as its pretty much same vehicle.
I test drove about 7 GLKs before finding one that did not show signs of some mechanical issue... and like any MB, you're never really out of the woods. happy hunting
I've been cross shopping the whole gamut of SUV's for a while. While MB Luxary, ride, style, and prestige appeals to my emotional side, utmost dependability and affordable maintenance appleals to my rational side. Goal is slightly tilted to the latter, as I will keep it for many years.
That said, something suddenly came my way last week, and in the process of evaluating this vehicle and decision. Don't want to say too much yet.
if you want a reliable dependable vehicle for many years a MB is not it. if you want to be comfortable, and drive a good looking car yes. but these vehicles certainly are not the pinnacle of dependability. did you even read the above post?
I always pay attention to the old cars I see on the roads. Cars from the 70s', 80's and 90s. There are some Hondas from the 90's, but most of the older cars are Mercedes and Volvo. But it took proper maintenance for all of them to last that long.
while the GLK is comparatively simple by design than say an S-Class, the 204 class is still plagued with too many issues to call them "utmost dependable".
routine maintenance is part of owning any vehicle. Simple service done at a MB dealer is prohibitively expensive, B service is what $500 for oil and brake flush lol. Add that on top of repairs. Some facets of 204 servicing are easy and cheap to DIY. A DIY B-Service is prob less than $100 at home.
Expecting these particular cars to give you 10 years of dependable service i think is a pipe dream. like any relationship, there is going to be some drama. unless you marry a toyota or honda.
I always end up thinking that making a car last forever is easy, but at the end of the day (or decade), do you WANT to make a RAV4 or RDX last 10 years? Or would you prefer a GLK or X3 or whatever else? If you are going to spend time and money, make sure it's what you WANT. Or you'll be trading in the car you settled for in a couple of years which makes you lose more money than it costs to buy what you want the first time.
Yes and I replied right after your rely with a big thank you. Did you see it? I'm sorry you didn't realize I was thanking you and others for the honesty.
To clarify, by saying previously that my purchase decision is slightly leaning towards long term dependability, I didn't mean to imply that I thought MB are or are not. I was just simply being honest too and expressing my needs.
Remember, I'm new to the brand, hence my post.
Bought an '04 Toyota 4Runner, V8, with only 32k miles for $9,500 from the original owner, a client of mine. It's nearly brand new condition. Couldn't pass up the opportunity. Divine intervention.
I may consider an SL or something fun for the weekends.
Thanks again for the help
