2015 glk 350 4matic
Old Sep 6, 2017 | 04:15 PM
jfish123's Avatar
2015 glk 350 4matic
2015 glk 350 4matic
I just bought a a 2015 glk 4matic and found that it has not spare (regular or deflated 'donut'). I drive a lot of hiway miles and would like to have a spare, just in case. The car currently has the 'run flat' tires on it.
Suggestions welcome!
Old Sep 6, 2017 | 06:08 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
If you are in the Los Angeles area I can give you my never used spare.
Old Sep 8, 2017 | 11:29 AM
Lazarus Long's Avatar
GLK 350 4 Matic
One suggestion is to get a small 12V air compressor and a can of fix-a-flat.
My strategy is if I get a low tire, re-inflate with the compressor. If the tire won't hold air, then get out the can of fix-a-flat and try again. If that doesn't work, call for help.
My GLK has run-flats (no spare), I carry a compressor anyway. While you can drive on a run-flat with no air, doing so will ruin it. If it goes low I will try re-inflating rather than just driving on it.
My Corvette originally came with run-flat tires (no spare), I just replaced them with regular (non run-flat) performance tires. I keep a compressor kit there too.
An air compressor is easier to use than trying to change a tire on the side of the road. Fortunately, I haven't had a need to try it out yet.
