'13 GLK250 BT, a slew of engine codes starting with P0101
Folks, I noticed the engine light on as I was leaving this morning (my wife said she hadn't noticed if it was on the day before). I ended up with what appeared to be the turbo's not kicking in, the tranny not shifting per the paddle wheels, and a huge loss in power (which I assume was the lack of turbos).
Did a code check and got the following which seems to possibly be related to the Mass Air Flow:
Current Fault Log
P0101: Mass or Volume Air Flow Circuit Range/Performance Problem
P0299: Unknown code - More information may be available on the web
Pending Fault Log
B2AAA: Unknown code - More information may be available on the web
P0171: System too Lean (Bank 1)
Historic Fault Log
Other discovered fault codes
(possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged
Any suggestions on what this might be? Do I try resetting the codes to see if they come right back? Anyone have a detailed description of what these codes are?
Thanks in advance.
Gordon
Current Fault Log
Pending Fault Log
Historic Fault Log
Thanks in advance.
Gordon
The main code is a MAF/MAP code, and I'm suspecting that it is in turn causing some of the others.
So my first step will be to clean the MAF sensor and I'll go from there. but if anyone has further info on these codes etc., that would be great.
Thanks.
