Front bumper removal (work in progress)
Old Sep 17, 2017 | 02:05 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
Removed
Old Sep 18, 2017 | 08:18 PM
JohnnyC's Avatar
Removed
Old Sep 19, 2017 | 10:50 AM
bop11's Avatar
350 GLK, C280
Nice. Thanks for the pictures. Lots of info even if you only need to remove the fender liner Good luck with the LEDs
Old Sep 20, 2017 | 09:13 AM
B737's Avatar
2012 GLK
Originally Posted by bop11
... you only need to remove the fender liner.
This.
Originally Posted by JohnnyC
Minimum time required: 1.5 hours.
Difficulty: Expert
expert level stuff here?
Old Sep 21, 2017 | 04:48 AM
suavebygtr's Avatar
GLK 350 4 MATIC
Hello, Regards from Spain,
Can you put the model of H7 led please? i will try to upgrade h7 halogen to LEd, and at the same way put D1S 6000K xenon lights.
Good POST!
Old Sep 21, 2017 | 04:53 AM
JohnnyC's Avatar
i considered it very difficult as I included my own headlight service in the rating
This was also my first time doing any major bodywork, so I took my time and went slowly. I actually had to remove the bumper twice and install twice between a few days because the original LED units were not drawing enough power and causing issues. Just so many chances to scratch paintwork or not aligning the bumper in install.
By the way anyone with the Bi-xenon lights I strongly recommend you to upgrade the turn lights to LED
Old Sep 21, 2017 | 05:00 AM
suavebygtr's Avatar
GLK 350 4 MATIC
Yes i will dot it, what is the model that you bought of H7 led lamp?
Old Sep 21, 2017 | 05:07 AM
JohnnyC's Avatar
Good POST!
I used Tireius, they are made in China and I suspect many are just rebranded from one company, you can find many similar ones.
https://www.amazon.es/dp/B072R4N78P/...ing=UTF8&psc=1
https://www.amazon.es/s/ref=nb_sb_no...eywords=h7+led
When I get my new headlights I will be switching to the uber expensive Philips
Old Sep 21, 2017 | 05:18 AM
suavebygtr's Avatar
GLK 350 4 MATIC
Thank you! and it's plug and play not? connect, and the car don't see warning advice its have can check?
Old Sep 21, 2017 | 05:29 AM
JohnnyC's Avatar
YES plug and play. Most the H7 LED units with the bulky fans have built in circuitry and resistors to control light output.
Do NOT buy Single bulbs like what I originally had.
