mercedes w168 a160 75kw 2000
Old Sep 20, 2017 | 04:14 AM
enes merc's Avatar
opel, mercedes, mitsubishi, zastava, nissan...
my car suddenly wont start up it have new spark plugs new fuel filter have fuel and all fuel instalation is ok and clean fuel pump is also clean and ok cps and camps is also ok what can be plesa help me
Old May 26, 2020 | 02:19 PM
GFSHTH's Avatar
1964 Mercedes Benz 220S W111 chassis, 2007 Mercedes Benz C230 Sport
I had the same problem with my 1964 Mercedes 220S.
Had a motor mechanic come out, remove the top halves of my Zenith carburetors, cleaned out the upper parts and then removed the sludge and residues in the lower bowls of the carburetors. Reinstalled the upper halves and spent time trying to start the car. It started after about 10 minutes. Now the car starts wonderfully and I use premium unleaded fuel. You may need to remove the fuel tank and deep clean it and the fuel lines.
And secondly, you may want to hook up a vacuum gauge to the intake manifold to check for leakage. And then check the timing with an appropriate gauge.
Don't give up, be patient, and this car should be fine. Good German product and a good investment car.
