Open Hood Warning - not open
Old Oct 24, 2017 | 12:10 PM
littlehandegan's Avatar
Gelandewagen
2010 GLK350. Getting an open hood warning but the hood is closed. What should I look for??
Old Oct 25, 2017 | 09:34 AM
bop11's Avatar
350 GLK, C280
Replace the hood sensor
Old Nov 17, 2017 | 04:51 PM
pschiller's Avatar
2013 GLK350 & 2013 E350
I have a 2013 E class with a similar warning message. I finally realized that you can't just let the hood drop or push from a foot above closure but instead let it drop from about 3 feet above the closure point with a good slam!
Old Feb 16, 2018 | 08:02 AM
ereynolds1978's Avatar
2013 GLK 350 4Matic
Another thing you could look at before replacing the hood sensor is adjusting the latches that go into the hood sensor. Mine take a 13mm wrench to adjust. You could adjust them to stick down into the latch sensor further (one to two threads) that should help the message go away.
