Is Diesel Fuel sold in USA going to kill our engines?
Mercedes says goodbye to diesel in North America Driving
Basically says that diesel fuel currently and in future available in USA will ruin our modern diesels and will void warranties.
Is it true that B5 diesel is not widely available? This is what article claims:
a maximum of up to 5% biodiesel] in all Common Rail Injection (CDI) and BlueTEC® diesel engines.
The only approved processed biodiesel for B5 blending is one that meets the ASTM D6751 specification, to prevent
damage to the engine and fuel system from deposits and/or corrosion.
The use of diesel fuels containing a higher percentage of biodiesel, (B6 to B20) according to ASTM D7467 as well as
straight biodiesel (B100) according to ASTM D6751 may cause severe damage to your engine and fuel system, and are not
approved by Mercedes-Benz.
The Mercedes-Benz New Vehicle Limited Warranty generally does not cover damage caused by the use of fuels that do not
meet Mercedes-Benz approved fuel standards.
Main thing for us to watch, is that we don't put B20 or higher into our GLK250s.
Consumer confidence is being shaken, and with the increases in efficiency of modern gassers, fewer and fewer will want to take the chance on diesels.
We own a GLk 250 and see 36 mpg average per tank, but any gains in fuel economy suffer when its time to service or even buy fuel in some places. Unless you drive a lot, gas may be a better financial choice over diesel.
Also consider that diesel isn’t as accepted as it is in Europe. The big German 3 have always struggled to gain wide spread acceptance in the US market.
i will be sad when or if MB and the other euro brands drop diesel as from their offerings here in the US.
OJ
I use an additive in my old diesel but was advised against them by the techs at MB for the 651 engine. Didn't ask why, just that they were not recommended.
Love my GLK but it looks like they're making it difficult to continue with it. All our fuel pumps in Cali have stamps on them giving the biodiesel info. Guess I have to start reading them!
Suggested this morning that it's the same as selling regular from a premium fuel pump.
Is there any additive that will make the engine run properly?
Thanks,
Jim
Top off with regular fuel and add some cetane diesel treatment (Power Service, etc). When you get the fuel level down to 1/2, top of again. Go on some long drives and run it into Regen if possible. Bio diesel will clog a DPF if run long enough. Run it until you have run as much of the fuel out of the tank as possible. I would also replace your fuel filters at your next oil change if not already part of your service.
Previously used Lucas upper cylinder lube/injector cleaner in both diesel and gasoline engines. Will look at the other suggested treatments.
Thanks,
Jim
