My power 2012 GLK 350 tailgate looks bent and is not closing
Old Jan 27, 2018 | 09:08 PM
Ray P's Avatar
GLK 350
My GLK 350 power tailgate is not closing. The car was taken to the local mechanic to fix a flat tire and remove the spare and place it back in the trunk. after the tire was fixed, my wife tried to open the power tailgate but it did not open. when she got home, my 9 yr old boy pushed the tailgate open from the inside,, the tailgate opened when he pushed from the inside but when she tried to close the tailgate would not close. When I got home I tried to close the tailgate but it look misaligned to the right in other words the left side of the tailgate looks higher at the hinge, so the latch is off center and it does not close, it is off a good 1/4 inch. can anybody tell me what can cause a tailgate to be off center and not close? Thanks Ray
Old Jan 29, 2018 | 09:24 AM
bop11's Avatar
350 GLK, C280
The repair guy did not know it was a power gate and slammed it down, probably with something in the left side of the opening.
Old Jan 30, 2018 | 08:34 AM
Mmr1's Avatar
2013 glk 350
You took it in for repairs, you got it home broken. Good luck getting them to admit anything.
Old Nov 23, 2020 | 08:53 PM
Suzii Spaulding's Avatar
Glk350
Same issue
I have the exact same issue, please tell me you got it fixed and figured out what it was.
how much was the repair? Was it a bent hinge?
please respond if you get this.
Old Nov 24, 2020 | 08:53 AM
tommyr's Avatar
25 GLE53, 24 Macan, 15 GLK350
The tailgate struts are notorious for failing, that would be a good place to start.
Old May 5, 2021 | 01:10 AM
Dipen Neupane's Avatar
GLK 350
Did you change the left tailgate hinge ?
Please, share with us how you repaired it.. my GLK has same issue alignment off on left side and not closing..
