2012 GLK 350 ALL Warning lights ON- won't shift, but engine starts
Mercedes Glk 350
It happens in the morning. When I start the car, the engine would start but all warning lights come out ( Cruise C Inoperative,Run Flat Inoperative,ABS Inoperative,SRS Malfunction,DSR Inoperative).Cannot shift gears. Engine works, but a bit louder than usual and as if a fan is turning on. Radio, mirrors and all electronics is not working.After a Few attempts, when the car heats a bit, I am able to shift into gear and it starts to work fine and only the check engine light is on while I am driving . The next morning same thing happens. Took to a mechanic, he cleared the codes, this morning the problem showed up again. It is an electrical problem or a sensor, but have someone had a similar thing and what can be done about it?
Thank you in advance!
14 GLK 250
This is EXACTLY what happened to to me yesterday. Had to take the bus today and purchased a diognoistic reader. My vehicle was working fine the night before. I was cleaning off the snow off my tires and wondering if I disconnected the sensor. I'm going to read the other posts below. Is your vehicle working well now? It's been a year so I would like to know if you found anything over that space of time. thanks
I have no idea if this could be an issue but if you have. “Auto stop start” you have a second battery above the Spare tire on the right. It controls electronics.
So today I was suppose to have my vehicle back from the dealership but all the phone, computers were down at the dealer. I was trying to arrange pickup and the service guy I was dealing with told me my part (F32 pre fuse box) just arrived and that my vehicle would be done until tomorrow afternoon if that! Not having a vehicle isnt an option. So after some thought, I called the service guy back and told him if he doesn't have a loaner for me, I'll drive the vehicle home using the bypass button. He said isnt the vehicle inoperatatable?? But the tow guy showed me how to bypass to be able to drive. WELL, when I received the keys to my vehicle it was back to NORMAL, back to the day before it couldn't drive. I was in SHOCK!!! I'm suppose to go back to the dealer and get the box installed but is this just a MONEY GRAB??? Did my vehicle just need their computers to reset everything?? The service guy swore to me I need to have the fuse replaced. Infact, the service guy doubted that i would return. I speculate its because nothing is wrong. I dont know what to do because I don't want this to keep happening.
hadeeeeez (06-11-2021)
If they have diagnostics saying the part is failing, they should be able to show you that?
and next time, be more aggressive about a loaner. Here, labor is $179 an hour. For that price, they can pull a car off the lot, for all I care. And perhaps my dealership is larger, but they’ll offer a loaner for something as simple as an A/B service.
mercedes benz glk 2012
It happens in the morning. When I start the car, the engine would start but all warning Ilights come out ( Cruise C Inoperative,Run Flat Inoperative,ABS Inoperative,SRS Malfunction,DSR Inoperative).Cannot shift gears. Engine works, but a bit louder than usual and as if a fan is turning on. Radio, mirrors and all electronics is not working.After a Few attempts, when the car heats a bit, I am able to shift into gear and it starts to work fine and only the check engine light is on while I am driving . The next morning same thing happens. Took to a mechanic, he cleared the codes, this morning the problem showed up again. It is an electrical problem or a sensor, but have someone had a similar thing and what can be done about it?
