2011 GLK350 Display Replacement?
Old Apr 8, 2018 | 09:40 PM
Marc Gobeil's Avatar
GLK350
So long story short took my GLK to an autobody place for some hail damage and got it back and there are lines across the screen. Its been a year fighting to have them replace it, it's going nowhere, going to just report them to the Better Business Bureau etc.
I don't mind doing the work myself, but I am not sure about getting a replacement unit. Seem to be plenty on eBay? but I am worried and want to avoid any potential issues like "Vin-Lock" etc? I have changed out a few stereos in my day but nothing like this. To be clear I would like a direct Factory replacement. I have Nav, not that I use it, but what do I need to watch out for?
Cheers
Marc
Old Nov 13, 2018 | 12:04 PM
ignorant's Avatar
2010 GL 550 + 2010 GLK 350
Hi Marc, I have the exact same problem. What did you do in the end to solve this?
Old Dec 3, 2018 | 12:36 PM
ignorant's Avatar
Is there a simple way to tell whether my display is broken or the mainboard?
Old Dec 3, 2018 | 01:47 PM
noah330's Avatar
glk350
I think the Nav unit is larger than the non-nav but I could be wrong about that. You may want to try unplugging it and cleaning the connector with something like DeOxit and plugging it back in. It could just be loose.
Old Dec 4, 2018 | 12:47 AM
ignorant's Avatar
vents out
display assembly out
display assembly disassembled
ordered this thingy
Ok, got really pissed off and tore the thing apart tonight.
Found a strong wire and bent it to a nice shape to pull out the vents.
Took the vents out, the rest was easy.
After full disassembly, identified the screen as LG LB070WV1-TD17 and went into aliexpress to order one.
Ordered to Canada from China. 7 day shipment included 155 USD (210 CAD).
Will assemble everything and lets see what,ll happen.
My display was not working, but audio was fine. We'll see what happens now.
Old Dec 4, 2018 | 12:52 AM
ignorant's Avatar
Molson Canadian + Dollarama Screwdriver (4 cad) helps a lot to build the courage.
Notes to self:
Invest in a good screwdriver set
Keep the beer as a trophy once you're done, not the other way round.
Old Dec 12, 2018 | 12:24 PM
ignorant's Avatar
UPDATE:
My screen arrived in 8 days from Aliexpress to Canada.
Looks identical and was perfectly protected.
Installed it back in 5 minutes and Voila!
PERFECT AND LOOKS BRAND NEW!
Less than $200 to install a brand new Comand screen!
Old Dec 21, 2018 | 01:22 AM
ignorant's Avatar
Update:
This was what I bought:
https://www.aliexpress.com/item/Free...7f194c4ddXTpJP
The model of the display is
LB070WV1-TD17
If you want to DIY, this was my screen.
Old Apr 17, 2023 | 11:21 AM
Okko's Avatar
GLK
Thanks for the update! My screen is not working but audio works fine. It keeps turning on and off and only shows the Mercedes logo. I'm gonna try this!
Old Apr 17, 2023 | 12:20 PM
habbyguy's Avatar
2011 GLK 350 4Matic
Okko, if the screen is showing the MB logo, the problem is NOT your screen, but what drives it (assuming every time it comes on it has the MB logo). It's kind of like if your TV was only displaying your cable box's start-up logo, you wouldn't replace your TV...
Old Apr 17, 2023 | 12:37 PM
Okko's Avatar
GLK
What do you think it could be? I tried changing the fuse as well and that didn’t help.
Old Apr 17, 2023 | 01:17 PM
habbyguy's Avatar
2011 GLK 350 4Matic
Happily, I have no idea... ;-) That is to say, I'm new to the GLK world, and haven't had to dig into my screen / nav / audio system (yet...).
Based on the photos of the screen in this thread, it's clear that "it's only the screen", and doesn't contain the processing for all the many functions that drive the screen.
It looks (according to my service manual) that the "radio unit" drives the display. This MIGHT NOT be exactly the same as your GLK, but I'm betting the basic architecture is the same throughout the entire GLK line...
Old Apr 18, 2023 | 12:31 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
The basic canbus architecture is the same for w204 and x204. That’s where it ends.
It is possible that this could be diagnosed exactly with Xentry. That would require having Xentry and the knowledge to use it, or an expensive trip to the dealer.
COMAND head units should be interchangeable IFF they are the same NTG version and have the same functions activated. NTG 4.0 was replaced by NTG 4.5 at the facelift. When replacing, it is best to get the part number from the original and get a replacement with the same part number.
The toss up is whether to replace the screen anyway, as it is definitely the easiest and may be the least expensive.
Old Apr 18, 2023 | 09:02 PM
MysticMan's Avatar
GLK350
You would want this in 12.3 size, I have it, it's a life changer: https://dmpcardes********/product/fa...-pre-facelift/
Join the community too: https://discord.gg/FKF6nW3j
Old Apr 19, 2023 | 09:57 AM
C300fan2's Avatar
14 GLK 250
Do you have any pics of it installed? Did you install it yourself?
Old Apr 19, 2023 | 12:02 PM
MysticMan's Avatar
GLK350
At first I had someone install a smaller screen locally, but then I wanted a larger one and learned how to do it myself, you would need tools like this to remove the central console: Elf Bee Instrument Cluster...
Amazon Amazon
