New brake pads, new end links and a brake bleeding job
The end links were as expected : not difficult, but a bit time-consuming. The rear ones were trickier than I thought, as the bottom end is tightly wedged in the control arm, so I literally had to jack the control arm to press the end link inside it.
I then bedded the pads and felt that while braking was slightly improved, it wasn't enough. I then bleeded the brakes with a friend... oh my... it's like I'm driving a different car. Tight pedal, great progressive feel, and confidence-inspiring braking. In retrospect, I should've bled the brakes first. Maybe I would've elected to keep the EBCs, but I still feel like they require a bit more heat than I can give them on my commute to work properly.
So if anyone wants cheap, barely used Redstuffs, let me know! They probably have less than 6k miles of easy driving on them.
