Water pump pulley failing
Old Oct 30, 2018 | 10:08 PM
SAVZ's Avatar
2010 GLK350 4matic
Can see it occasionally move in the video, I'm guessing I will have to change out the pump. No other symptoms. Anyone have water pump pulley issues similar to this?
Old Oct 31, 2018 | 08:34 AM
andreigbs's Avatar
GLK 250
Dumb question: that bolt holding it on is guten tight, ya?
Old Oct 31, 2018 | 12:58 PM
bop11's Avatar
350 GLK, C280
Looks like bad bearings in the pump. I would get it replaced before the seals go and you blow coolant all over the ground while it over heats.
Old Oct 31, 2018 | 06:24 PM
formerjeepguy's Avatar
2015 GLK350
Exactly this. The water pump is gone so replace it ASAP.
Old Nov 2, 2018 | 10:03 AM
SAVZ's Avatar
2010 GLK350 4matic
​​​​​Thanks, was going to replace the tensioner and belt and then noticed the pump pulley. A new one is on the way.
Old Nov 12, 2018 | 12:46 PM
SAVZ's Avatar
2010 GLK350 4matic
So I replaced the pump, tensioner and belt, but now the car won't start
Old Nov 13, 2018 | 09:33 PM
bop11's Avatar
350 GLK, C280
did you hook the battery up? Do you mean it won't crank or it won't start?
Old Nov 14, 2018 | 09:32 AM
107123210's Avatar
Well if you run the video bop11, the engine is turning over.
SAZ - Check if you may have disturbed some wiring or tubing.. Would have to be something that affects complete ignition or injection.
Old Nov 14, 2018 | 10:52 PM
SAVZ's Avatar
2010 GLK350 4matic
​​​​I took out the secondary air pump during install and put it back in. I took that out again just now to see if any of the wires and hoses were lose but everything visually appears connected.
Old Nov 14, 2018 | 10:53 PM
SAVZ's Avatar
2010 GLK350 4matic
Battery was never disconnect, it is turning over juts not starting, as on the video
Old Nov 16, 2018 | 12:16 PM
2015 GLK350
My best guess is that some electrical connector was dislodged in the process of changing the pump/tensioner. And it almost certainly has to be setting a code in the computer. You need to hook up a mercedes aware OBD2 scanner to see what the complaint it. That should point you to what needs attention.
Old Nov 16, 2018 | 02:19 PM
107123210's Avatar
Maybe camshaft position sensors? I don't know engine, but they should be somewhere on each side front of engine. I know the crankshaft Position sensor will prevent car from starting (but it is usually at back)
Old Nov 23, 2018 | 05:43 PM
SAVZ's Avatar
2010 GLK350 4matic
So it ended up being the ESL, car is running fine now
Old Nov 23, 2018 | 06:16 PM
GLK350-2011's Avatar
2011 GLK 350 4matic
For the curious minds who want to know.....how did you solve the ESL problem?
Old Nov 23, 2018 | 06:57 PM
SAVZ's Avatar
2010 GLK350 4matic
I didn't have anymore time to play around with the car, took it to an independent mechanic. He confirmed the ESL issue, ordered and installed the part.
