High Beam Options (LEDs?)
2013 GLK 350 4MATIC (Polar White)
Hey Guys,
Was hoping for any of you that upgraded your high beams into some sort of LED type? Any sources and experiences would be greatly appreciated.
With millions of decoders and H15 LED bulbs out there, my hopes is to narrow it down from someone who's had a very good experience with a pair.
Thanks,
Johne.
Thanks,
Johne.
SPONSOR/MBworld Guru
LEDs in housing not designed to capture LED surface mounted light spread will result in reduced throw distance, light scatter, and elongated dark spots. LEDs have single point spread where the edges will not be as bright causing somewhat dead spots. HIDs will be a better solution for your high beams as it's true 360 like your halogen bulbs so your housing will be able to better capture and use that light. Not to say LEDs are bad as they'll probably still be better than halogens, but HIDs will be better.
Thanks,
Johne.
I just googled up h16 HID, I use Philips low beam Hid , I’d stay away from led unless you can try them and return them . ( a pain ) For low beam I think hid will outlast led because of heat issues affecting led.
Hey Guys,
So a little update. I ended up buying a pair of H15 LEDs that I saw someone installed on YouTube. It’s made by Lasfit and I bought it from Amazon. I must say, I was very impressed. The lighting output seems to be as good as the 55W HID kit I have for the low beams! I’ve also been driving around for the past couple of days without any warning lights. I’ll try and post pics/videos soon.
Link to Amazon:
Johne.
Link to Amazon:
Johne.
Hey Guys,
Link to Amazon:
https://www.amazon.com/dp/B073Y33F5P..._d04vAbPJKP657
Johne.
Link to Amazon:
Johne.
I have used these for high and low beams in both my GLK's. been in there for 4 months. No failures. They are pigs to install in the high beams, lots of cut fingers and pain - but got it done. Light pattern is same as original, the intensity on the low beams is higher, but managed well with the projector pattern. The high beams are much better light temperature (daylight, vs. halogen) and the brightness is higher (roughly 2x lumens). these LEDs have elements on three sides and pretty much produce the same pattern ad a filament bulb. Great price and really good quality...
