2015 GLK350 Brakes & Rotors Yearly Replacement
Old Nov 29, 2019 | 09:39 PM
Mmr1's Avatar
2013 glk 350
How do the rear brakes wear compared to the front , they should wear about 30% more to double , how about a bad Proportioning valve making the fronts do all the work?
Old Nov 30, 2019 | 08:02 AM
NYCGLK's Avatar
GLK 350 / Porsche 993
The rears are working and wearing, the pads are def more worn in the rear then in front. Even if fronts were doing more work, you would see front pads going quickly.
This rotor issue is known issue across many GLKs including pretty new ones. I think it's MB pads or caliper design, but this is just a guess.
Btw...MB doesn't bother with L/R rotor up front (or rear), L/R are the same rotor even tho inside vanes are angled...But then again, both rotors get warped not just one...
Old Nov 30, 2019 | 10:47 AM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
On both of my GLK350s the brakes were wearing normally when I replaced them.
My 2015 factory brake pads and rotors at 35,000 miles (56,000 km) were in superb shape. The surface was very smooth and even.
On the 2013 I had, I replaced the brakes with Akebono and Brembo hardware around 70,000 miles (112,000 km). Before I sold it at 90,000 miles (144,000 km), I inspected the brakes again and they looked like they were wearing evenly and normal. Keep in mind I do city driving in Los Angeles with heavy traffic.
