GLK250 and Star Tool Adaptation Inquiry
1 . Changing the Engine Air Filter
2. Remove and replace the driver side Air Charging Hose from the Intercooler (Being replaced due to a crack in the hose. As a temporary measure I used epoxy and duck tape and the CEL and all codes cleared)
3. Transmission filter and fluid change
My car is a 2014 GLK250.
I'm getting the feeling their use of the Star Tool for these types of repair and normal maintenance is inflating the bill unnecessarily. Are these 'adaptations' really necessary? Your thoughts please. And thanks for responding.
Dan C aka dofdear
You don't need it in order to replace the engine air filter.
You technically don't need it for the tranny flush, fill & filter. It makes it easier perhaps, but draining the fluid and replacing the filter is largely a hands-on tech-free job. I'd be more interested in knowing if they'll drain the torque converter as well, since that's usually skipped.
Bottom line: the scan tool can help with maintenance and repairs that are ECU-related, especially if there are codes stored that need clearing. You don't need the tool to accomplish the above tasks.
Could you post what they're charging for each job?
Sch B = $248
Trans Filter and Fluid = $216
Diff Service Front = $68
Diff Service Rear = $68
R&R Drivers Charge Hose = $208
All plus parts. Based on your response I'll change the hose myself and use my Foxwell scan tool to reset codes. Sounds like adaptation not required...'Thanks,
Dan C aka dofdear
I’d only have them do the “dirty” work of the tranny fluids and diffs.
