GLK 250 shifting to neutral at stops...?!?
Old Jan 14, 2020 | 01:59 PM
Jay072's Avatar
2013 GLK 250
Hi everyone!!
Had my (new to me) 2013 GLK250 for a couple months and really really like it so far!! Question: Is it normal for the transmission to automatically shift into neutral after coming to a full stop?? Trying to confirm my suspicions but not having much luck with thread search's or owners manual so far. I notice a momentary feeling of a shift into gear after taking foot off the brake pedal and off I go...compared with physically moving the gear select down into "D" with foot still on brake (can feel it shift into gear) then after releasing brake pedal,can accelerate immediately without that momentary hesitation.
Sorry if this has been addressed over and over but just wanted to confirm this is actually what happens. I've seen the posts related to a "thump" after coming to a stop...but I have never heard or noticed that, just this sensation that the trans goes into neutral after making a complete stop??
Old Jan 14, 2020 | 02:34 PM
andreigbs's Avatar
GLK 250
Unless the display indicator goes from D to N, you can be sure the transmission is not being placed in neutral.
What you're feeling might just be the braking hold and release delay, which is relatively normal.
How many miles and when was the transmission fluid last replaced?
Old Jan 14, 2020 | 06:24 PM
Jay072's Avatar
2013 GLK 250
Hi, thank's for responding...currently it has a little over 60,000 miles on the odo. Can't say when, or even if the trans fluid has been changed yet. I figured it was a fuel saving thing by disengaging the trans at idle when stopped at a traffic light etc. This is happening even without activating the brake "HOLD" feature. Hoping this was a normal thing as I'm still just getting used to the car and discovering more and more little "Easter egg" features, and just wanted to ask around before going to the local MB dealer...
Old Jan 15, 2020 | 10:35 AM
andreigbs's Avatar
GLK 250
I would plan on having your transmission, complete with torque converter and transfer case (all one unit basically) flushed and filled with the MB spec stuff. It's cheap insurance against a damaged transmission due to low or degraded oil later on.
An Indy shop should be able to do the entire driveline (including rear diff) for no more than a few hundred. Shop around, find one with good reviews that works on German cars and do it as preventive/scheduled maintenance every 60k.
At least that's my advice. Our GLK250 is rolling along at almost 120K miles and will be due for its 2nd driveline flush & fill.
Happy dieseling.
Old Jan 15, 2020 | 10:53 AM
beeguz's Avatar
2001 SLK 2017 Chevy Bolt, 2019 Subaru Crosstrek
To me it sounds like your fluid level is low now what is happening is when you stop the transmission pump is dropping limited amount of fluid.
When you step on the gas it picks up the fluid, this was a very common sign of low fluid on almost ever automatic transmission ever built.
Right now the most important thing is to add some fluid, just so you don't damage the transmission, I would add 1/2 quart until you can have it checked the proper way for your car.
At 60K you are due for a fluid change, that is unless you believe that fluid filled for life bunk that dealers push to sell more cars.
Old Feb 2, 2025 | 09:26 AM
300SE1993's Avatar
2012 S350 Bluetec, 2014 GLK250 Bluetec, 2026 E350 4Matic
Reviving this thread - There's definitely something to this. When you come to a stop in one of these, after a few seconds, you feel something, almost like the car is shifting to neutral while you are stopped. You can hear it too. I vaguely remember reading some tech info on the 7gtronic pus that it does this, but can't seem to find it now.
Old Feb 8, 2025 | 09:20 PM
fei_cdn's Avatar
2015 GLK 250
Here is a topic I posted about this issue myself:
https://mbworld.org/forums/glk-class...rake-stop.html
Old Feb 9, 2025 | 11:20 AM
300SE1993's Avatar
I never had the surging
