Glk 350 4matic transfer case
Old Jul 20, 2020 | 09:53 AM
Mmr1's Avatar
2013 glk 350
I have a 2013 glk 350 4 matic , does the transfer case have its own oil supply that can be changed , I can’t find any info on the glk, I find information on many other mb, I’m trying to change all fluids.
Old Jul 22, 2020 | 01:46 PM
NYCGLK's Avatar
GLK 350 / Porsche 993
Transfer case is part of the transmission on GLK and hence uses the same fluid - it's one unit.
Front and rear differential use different fluid.
Old Jul 22, 2020 | 02:24 PM
Mmr1's Avatar
2013 glk 350
Then There is no changing of the transfer case fluid?
When you change the transmission fluid it’s automatically done ?
Old Jul 22, 2020 | 03:08 PM
NYCGLK's Avatar
Correct for GLK/E/C. ML/GLE have separate transfer case
Old Jan 9, 2023 | 02:11 PM
GLKattitude's Avatar
2013 GLK 350
It can be confusing but Yes NYGLK is perfectly correct above. Confusing because there is both a drain and a completely hidden fill plug in the rear t-case area. It's not 100% necessary to utilize these during a service however, as fluid naturally cycles through the T-case area during operation (has a "flow-in hole and a "flow-out hole between T-case area and Transmission internals). Ask me how I know? During my T-case repair I managed to get the upper fill plug out but it took forever to get it back in and tightened. I did not remove the Trans, just dropped it down.
