Aux Battery affecting Key Fobs?
Old Jan 9, 2023 | 10:48 AM
spamgnome's Avatar
GLK250
I've had my 2013 GLK250 for about 4 years now (bought used), and the other day received the "Auxiliary Battery Failure" message. I actually didn't even know that the car had one, but now I know! I located it, removed it, and put a volt meter to it. Dead. Like...0 volts! New battery on order, so not a big deal. HOWEVER, before the message appeared, neither of my key fobs would work, even though the batteries show 2.97V. I know that's not brand new, but still high. As I was doing some research on the purpose of the aux battery, I'm now wondering if the inop key fobs are related to the aux battery. I guess when the new battery arrives, I'll know for sure, but wondering if someone knows. Thanks! This is my 1st post here, so go easy on me.
F.
Old Jan 9, 2023 | 12:37 PM
chassis's Avatar
2017 GLE350 4MATIC
Measuring voltage on batteries is meaningless. instal new fob batteries, aux battery and main battery if it has not been changed during your ownership. Less then perfect batteries can cause many "unexplained" electrical oddities on modern vehicles, which are rolling computers.
Old Jan 9, 2023 | 03:01 PM
andreigbs's Avatar
GLK 250
Curious as to where exactly you found the Aux battery.
Old Jan 9, 2023 | 03:11 PM
GLKattitude's Avatar
2013 GLK 350
I have a 350 and it's in the trunk on the right; However, I believe on a 250 it's inside the dash board behind the panel accessible when drivers door is opened.
Old Jan 9, 2023 | 03:17 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
F.
I recently got the constant "Aux Battery Malfunction" message on our 2014 GLK.
It was like that for over a month - I never use ECO mode (switch if off as I'm starting it), so wasn't too concerned about replacing it immediately.
But after a month of having to tap OK to dismiss the message, I went and bought a new Aux battery at Oreilly Auto Parts.
I replaced it in the parking lot (about 5 minutes) to save a trip back to Oreilly and core charge
BTW, it never affected the use of the key FOB.
Old Jan 10, 2023 | 04:30 AM
KanataSteve's Avatar
2013 GLK350 Canada
Had to change my 350's Aux battery, it didn't affect my fob. Fob battery had to be changed months later.
Pro tip: Don't use cheap dime store fob batteries. They don't last.
Old Jan 10, 2023 | 10:09 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Don't you mean Dollar store? I haven't seen a dime store in about 60 years.
It's a 3 volt battery. If it shows less than 3 volts it's probably bad. A new one may show as high as 3.4 volts.
Old Jan 10, 2023 | 11:05 AM
2013 GLK350 Canada
Yup, dime stores are now a part of history, just a fond memory from long ago
Old Jan 10, 2023 | 06:23 PM
spamgnome's Avatar
GLK250
I found the battery on Amazon. About $42 + shipping. Also picked up some fob batteries at Harbor Freight...cheaper than a dime store!
Old Jan 10, 2023 | 06:40 PM
andreigbs's Avatar
GLK 250
Would you have the link to the battery?
Old Jan 11, 2023 | 09:27 AM
spamgnome's Avatar
GLK250
Amazon Amazon
Old Jan 11, 2023 | 11:37 AM
bugelrex's Avatar
glk
F.
How's the replacement difficulty? Do you need any special tools?
Old Jan 11, 2023 | 01:07 PM
calder-cay's Avatar
It depends ... is your Aux Battery in the spare tire area as with GLK 350's or is it a 250 ??
On our GLK350 (spare tire area), took me 15 minutes, by removing the battery cover, and using standard metric sockets.
Can't speak for the 250...
Old Jan 11, 2023 | 02:35 PM
spamgnome's Avatar
GLK250
Super easy, but a tad awkward. The whole process of removal took maybe 10 minutes, if that.
1. Remove 3 torx screws from the front of the "kick panel" under the steering wheel. This will allow you to get your hand underneath the dash to manipulate the position of the battery. No need to remove the panel, just be able to get your hand up there.
3. Remove the plastic cover on the left side of the dash. I used plastic tools that are made for this purpose and don't mar the surfaces.
4. Remove the bolt (10mm) that becomes very obvious once you remove the plastic panel. That screw holds a tray in which the battery is cradled.
5. Use both hands to position the battery (it's behind some felt) such that you can pull off the terminals. This is why you removed the bottom panel.
6. Use both hands to remove the battery from the cradle. I think you can probably also remove the cradle, but there's not a need.
7. Now just wriggle the battery out of the square hole on the side of the dash.
