Looking to add a GLK 350 4matic
Old May 11, 2021 | 10:13 PM
NY450SEL's Avatar
S4/M3
New member introduction. I've never owned a Mercedes, but have owned 3 BMWs and an Audi - so some familiarity with Germans. Currently, daily a '15 S4, and summer weekends in a '98 M3 convertible.
Looking to add a GLK for my wife for utility purposes. She had been looking at GLAs, but we weren't very impressed, and she preferred the aesthetic of the GLK - I agree - and the higher build quality. Looking for a low mileage 2015 with full service records - oil, fluids, etc.
These vehicles all seem to be configured very closely: Premium 1, keyless, heated seats, nav...a few with lane assist/blind spot, a few with the AMG package or 20" wheels, none with the HID lights that I've found
From reading around here, seems like primary issues are transfer case failure (35k ATF fluid change), lift gate motor, seat surfaces for the leatherette.
Apart from the above, and checking wear items - tires, brakes, suspension rubber, anything else to be on the look out for?
Old May 12, 2021 | 10:03 AM
andreigbs's Avatar
GLK 250
Motor mounts can be a PITA, also maintenance items such as replacing spark plugs.
If equipped with auto start/stop system, the auxilliary battery needs replacing likely.
Some complain of warped front rotors. Replacing with heat-treated rotors and ceramic pads helps.
On 4Matics, the front diff U-joint can come loose creating all sorts of mayhem.
The HIDs option was rare for most GLK. You can retrofit replicas but not without some coding. I'd keep looking if good lighting is important.
Old May 12, 2021 | 07:56 PM
NY450SEL's Avatar
S4/M3
Thanks for the input...looking at a 2015, 30k miles, sorting through the MB service history. Brakes good, tires good, recent Service B, regular oil changes, etc.
I'm going to ask for an ATF change and plan to do plugs/coils when I get it home.
There's a couple items I can't figure out from the service history (thoughts?):
- "climate control service"
- "Express V6 10 30 50K"
Old May 13, 2021 | 09:38 AM
Mmr1's Avatar
2013 glk 350
Try the ac after it’s been sitting , mold is known to develop on the condenser. I just had mine treated yesterday, I hope it’s better. Yes do the trans fluid, MB’s time has proven to be to long. Mine was slipping when hot at 50,000 miles, changing the oil fixed it so far.
