Newbie here, hello all! Changing my Battery for the first time
Those places should match the battery to your car.
Those days lot of sites will force you to buy AGM, but flooded batteries seems to last longer.
4. AGM start being marketed in America about year 2012, while per my knowledge European models still used flooded batteries. X204 was design to work with flooded batteries and I doubt the software changed it over the years. There is simply no need for changes.
The factory AGM battery lasted 5 years, replaced it with a Duralast Platinum flooded which only lasted 1.5 years, went back in with a Advanced Auto AGM and it's going on 5 years with no issues.
Besides, you can go to Batteries Plus and get a Duracell AGM for $200 with a 5 year replacement warranty.
What would justify buying a flooded battery for the same price as an AGM?
I wont bother repeating what others have already said on this thread other than my personal experience shows that the AGM battery is needed unless you want to replace the battery every couple of years.
The previous post not withstanding,
I thought that was the realm of the SLA battery. But the AGM will maintain power long enough for mBrace to call for help in a rollover.
AGM batteries consistently have a shorter warranty than an equivalent flooded cell battery from the same manufacturer, typically 3 years vs. 4.
Varta is owned by Johnson Controls, as are many other brands.
Bosch batteries are made by Exide, as are many other brands.
Most of the rest are made by East Penn, including NAPA, which only carry an 18 month warranty.
The same NAPA battery, under the O'Reilly name, carries a 3 year warranty but costs $10 more.
Most of the rest are made by New Penn, including NAPA, which only carry an 18 month warranty.
1 . They last longer , easily 7 -9 years, mine was still fine at about 450cca when I replaced it at 8 years. I just didn’t want to go through -20f without assurances.
2 . They can be discharged to a much lower voltage without damage , unlike lead a acid. One full discharge can ruin a lead acid battery . No so with AGM.
3 . You don’t have to worry about corroded terminals or hydrogen gas , as they are dry and sealed.
4. They hold a charge longer than lead acid. They don’t self discharge as fast. This is needed for all the electronics you have.
5 it won’t leak if cracked in an accident.
It is a better battery, yes it costs more. Your mb was designed for it. That battery box cover will hold hydrogen gas from a lead acid , that will corrode your terminals. You don’t get corrosion with an AGM . Think of needing to clean your terminals every year or so because you didn’t get an AGM. My 8 year old terminals didn’t need cleaning. I don’t understand the warranty issue, but in real life they work better.
https://www.johnsoncontrols.com/insi...-car-batteries
In January 2018, Energizer announced it was purchasing the global battery and lighting division from Spectrum Brands, which includes the Ray-O-Vac and Varta brands, for $2 billion in cash.[7] This acquisition was finalized in January 2019 after a lengthy regulatory approval process. In November 2018, Energizer also purchased the global auto care division from Spectrum (brands which include Armor All, STP, and A/C Pro) for $1.25 billion in cash and stock.
but then i see stuff from 2017 and 2020 that sayt JC owns it.
Maybe it is all one giant company that says they are many company's for legal reasons.
Sounds like flashlight batteries, not automotive batteries. That would fit better with the "number of personal care businesses," too.
Johnson Controls automotive battery business was spun off in 2019 an now operates under the name "Clarios" and manufactures [the rest is pasted from Wikipedia] automotive batteries for passenger cars, heavy and light duty trucks, utility vehicles, motorcycles, golf carts and boats. It supplies more than one third of the world's lead-acid batteries to automakers and aftermarket retailers including Wal-Mart, Sears, Toyota, and BMW. Lead acid battery brands produced under this business unit include Continental, OPTIMA, Heliar, LTH, Delkor and VARTA automotive batteries
If not driving for prolonged periods (a week or more) or taking only short drives, use trickle charger.
