Low on coolant. Don’t know what to use to top off. Any suggestion?
Some background, to address leak issues.
I had a Toyota with a slow coolant leak. I monitored the level, and added coolant and distilled water(50/50) to keep it topped off. I noticed there was a direct correlation between the coolant level going down, and the normal engine temperature going up(duh).
I determined that I had a top end leak, or possibly a pinhole in the top end of the radiator.
Turned out to be an old hose.
If I was having the same issue, and my driving was mostly in a desert climate, I decided not to get myself in a Death Valley overheat situation from low coolant that might have even devolved into no coolant. Advice to OP, find the leak, and address it.
BTW-Thanks for the chemistry lesson. When I saw 2-ethylhexanoic acid I said to myself, “What the … is a fatty acid doing in anti-freeze?” I used to keep up with coolants in my Dupont Telar days, but haven’t dug deep for years, concentrating on lubricants instead.
And of course, change the coolant with the appropriate kind for your vehicle at the recommended interval, to make sure you have the correct concentration. But to just top off? Water.
