cannot shift out of park. cold weather/battery issue?
Old Feb 1, 2022 | 02:16 PM
bugelrex's Avatar
glk
Found some older posts with similar problem but no conclusions.
Twice this month I've been unable to shift out of park. Weather was around 15-20F
My battery is definitely on the older side (8 years). i suspect the car is detecting a weak battery and wont shift until the alternator charges the battery for 20mins?
- car starts but won't shift out of park. I had to idle it for 20 mins and then restart until it finally shifted
- windows, lights etc still work
- brake lights still work
Old Feb 1, 2022 | 10:06 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
More likely something in the safety or locking mechanism is hanging ("freezing") up. My battery was weak and it wouldn't start at -15F, but at -5 it was crank it up and go. Even at -15, as soon as I jumped it, everything worked.
Old Feb 2, 2022 | 11:39 AM
KTM530's Avatar
GLK250
Take a look at this video, might lead you to something. X30/21 Drive train can voltage distributor might be defective. Don't know were it is in our x204 model but in this video, it is in the passenger side. Seems to be a common problem for Mercedes. Hope this help.
Old Feb 2, 2022 | 12:32 PM
Mmr1's Avatar
2013 glk 350
“My battery is on the older side” no your battery is barely alive , keeping an 8 year old battery isn’t smart. Your just asking for trouble. Low voltage can also damage electronics. a new AGM battery is a good idea.
Old Feb 3, 2022 | 11:09 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
2015 GLK350 started similar behavior. ECO Start/Stop also stopped working. No real diagnosis was done, but 5+ yo main battery failed load test at B Service. Replaced main and aux batteries and problems went away.
