Wiper blade recommendations for the best streak free, glass hugging wipe?
First clean the glass with something stronger than windex. Then I use Zud (a kitchen cleanser) because it contains Oxalic acid and really cleans glass , I think regular kitchen cleanser like Comet will do good, then use a razor blade to go over it. Even a buffer and polishing compound should work.
For wipers you could just go to the auto store and get their best / most expensive wiper, I think I use Michelin and they cost like 60$ . Or also go on YouTube and look up wiper blade reviews. There are big differences, I’m guessing the newer silicone blades should last the longest.
I believe the divider is before and up to Jan 2014 builds are "early" while builds after Jan 2014 are "late." (May be wrong on the actual month, not sure)
The early style is up through Jan 31, 2014, chassis 301228, plus numbers 301334, 301498, 301851 and 333528.
To chassis 301228 Build date 1/31/2014 including chassis 301334, 301498, 301851 and 333528, excluding 301096
Late style:
From Chassis 301229 Build date 1/31/2014 Excluding chassis 301334, 301498, 301851 and 333528, including 301096
