TORQUE CONVERTER REPLACEMENT
Old Mar 2, 2022 | 04:32 PM
titang9's Avatar
2013 ML350 DIESEL
I'm a mechanic (not Mercedes).
If I replace the transmission torque converter, do I need to do any reprogramming? Or just install and run?
FEB/2010 GLK350 (204.956)
VIN: WDCGG5GB4AF471611
Old Mar 3, 2022 | 10:06 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
This worked for me:
Transmission adaptive learn reset procedure.
1. Turn the key to position II (run). Do not start the engine.
2. Press the throttle to the floor. Activate the kickdown switch.
3. Keep the gas pedal pressed for at least 10 seconds.
4. Turn key to OFF, position 0. Don’t remove the key.
5. Release the gas pedal.
6. Wait 2 minutes. During this process, key is left in the ignition in the OFF position.
7. Start the car and drive for 15 minutes.
Old Mar 3, 2022 | 11:29 AM
titang9's Avatar
2013 ML350 DIESEL
Originally Posted by John CC
This worked for me:
THANKS, THEN I/LL DO IT.
