Oil in coolant
Old Apr 19, 2022 | 10:32 AM
Brigus's Avatar
2021 Cabrio E53, 2014 Moto Guzzi California
Oil in coolant
Glk 350, 80,000 km, 2012, v6, 4matic
Dealer inspection, oil in coolant. No coolant in oil.
suggested new oil filter housing and thermostat.
this puzzles me; oil/coolant crossover is usually due to a head gasket, where the two fluids are thinly separated.
the oil lines and coolant lines do not appear close anywhere else.
I did read than oil cooler failure may cause hot oil to seep into the coolant lines.
1. think they have it right?
2. Are these do it yourself repairs? (Assuming a fair skill level)
Old Apr 19, 2022 | 11:48 AM
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
1. Meh!
2. Yes
Old Apr 19, 2022 | 03:02 PM
Mmr1's Avatar
2013 glk 350
Engine or transmission oil? Where is the transmission cooler? In the radiator or separate?
Old Apr 19, 2022 | 06:30 PM
Brigus's Avatar
I am blog deficient.
oil was reported in coolant reservoir.
no coolant in engine or transmission fluids.
deemed to be coolant line going through oil filter housing.
Old Apr 19, 2022 | 08:14 PM
Brigus, I forgot to say hi from a fellow Guzzisti.
Old Apr 19, 2022 | 09:47 PM
Brigus's Avatar
Just getting ready for the season. Lots of snow this year on the prairies.
Old Apr 19, 2022 | 10:42 PM
NYCGLK's Avatar
GLK 350 / Porsche 993
Sounds like total BS and close to fraud. Find another dealer - or never go to a dealer. Find a good honest mechanic if you don't diy.
The recommended repairs have nothing to do with the problem either. Both would be very simple job that they would charge lot of money fore.
Last time I went to dealer they could not figure out which light bulb needed replacement (not a joke). So I don't bother any more.
You are right blown head-gasket or failed oil cooler (warmer) is where the two fluids meet.
Old Apr 20, 2022 | 05:49 AM
Mmr1's Avatar
2013 glk 350
Pick up a cylinder head leak tester to check for a head gasket leak , maybe 20$, you put it on top of the radiator expansion tank and it measures if any exhaust gas is present in the antifreeze, it is possible the transmission cooler is inside the radiator and the transmission mission is loosing oil, but since mb is so smart, they made it impossible for you to check it. I never go to a dealer, they are 3-5x higher in price .
Old Apr 21, 2022 | 02:57 AM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Very common issue due to old gasket at the oil filter housing/cooler. All M272 and M273 motors suffer from this problem. And yes, the thermostat has to be removed but most of the time they come apart, so a new one needs to be installed.
Old Apr 21, 2022 | 07:30 AM
Mmr1's Avatar
2013 glk 350
Q
Old Apr 24, 2022 | 07:29 PM
Columbus430's Avatar
GL450
I have a 2013 GL450 (M278)and am having the same issue. My mechanic says it's definitely not the head gasket. Is this probably my oil cooler or transmission cooler also?
Old Apr 24, 2022 | 10:37 PM
Brigus's Avatar
It appears the coolant runs through the oil filter housing, as part of them oil cooler. So I am told. Will post the results after the recommended repair.
Old Apr 25, 2022 | 10:00 PM
NYCGLK's Avatar
I guess it's true that oil cooler/warmer is part of oil filter housing. I'm surprised it failed so early.
Good pic here: https://www.ebay.com/itm/184900269299
Old Apr 25, 2022 | 10:10 PM
NYCGLK's Avatar
Old Apr 26, 2022 | 09:54 AM
MBKLUE's Avatar
Yikes:
Do you know if the M276 engine, on the updated GLK, has this same oil filter set up and if so, is it affected by the same problem?
Old May 1, 2022 | 06:49 PM
Brigus's Avatar
Work is done.
had a private mechanic review.
It was supported.
I suppose that one is shocked when Mercedes touts its reputation for reliability, and find out they are worse than Fords.
Old May 2, 2022 | 09:41 AM
andreigbs's Avatar
GLK 250
Originally Posted by Brigus
Work is done.
It was supported.
Glad to hear the failure was fixed. Most likely a gasket that failed, thus allowing the oil and coolant to mix.
And clearly, you have either not owned enough Fords or Mercedes to know better
