Gas smell all over the car
Mechanic likely damaged the fuel filler or carbon canister components. Tell him to get back in there and fix what he broke.
It sounds like regarding the mechanic's work "something happened".
If the gas smell started AFTER the rear spring coil replacement, then it's possible this issue is a side effect of the use of the torch. The residual heat may have damaged a "gas component" in the area.
I'd also add this issue needs to be addressed asap!
