M272 VS M276
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
Hello guys, I am new member and I want to know which engine is more reliable for GLK 350. Is it M272 or M276?
As I am about to buy a vehicle, help me pleeeaaaasse.
chassis (01-15-2023)
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Start with these two articles from the same author
https://tuningpro.co/4-common-merced...gine-problems/
https://tuningpro.co/the-4-most-comm...gine-problems/
Omasha90 (01-15-2023)
Those articles are good reads despite a few glaring inaccuracies regarding the m276. It is in fact NOT related to the Chrysler pentastar v6. Both engines share a 60 deg v angle and that is ALL.
Article also says a 2012 intro but everything else I’ve seen says a 2013 intro for the m276.
Diamler Chrysler AG dumped off “Chrysler” in 2008 to a group of investors and removed Chrysler from the company name.
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,955 Likes
2017 GLE350 4MATIC
Aspects of reliability for the M276:
- 60 degree engine block, unlike the M272 with a 90 degree engine block which requires a balancer assembly which fails
- intake manifold which so far has not shown itself to have similar problems as the M272 with tumble flap failure
- no severe intake valve carbon buildup. All modern engines have intake valve carbon deposits, it is a question of how severe. The M276 seems to be OK with this.
- no cylinder scoring
- no cylinder head or valve guide failure
- no piston cracking
The above comments are based on experience posted on this site to date. Confidence is warranted given the number of years and production volume achieved for the M276. It would be unlikely, although possible, for some of these problems to appear. But at this late stage of the M276 lifecycle, the coast is clear.
The following 7 users liked this post by chassis:
AlbEder (07-25-2024),
GLKattitude (01-15-2023),
Odd Piggy (01-15-2023),
Omasha90 (01-16-2023),
skylashtravels (03-28-2024),
and 2 others liked this post.
The M276 is arguably the most reliable MB engine in the past 20 years. Early years for the M276 had problems with timing chain tensioners, for which a dealer fix is available, if it has not already been done on the vehicle. This is known as the "check valve" issue and fix. Besides this, there are no systemic or catastrophic problems that have surfaced yet with the M276. For a period of time, the M276 was the workhorse engine for MB, being used in the C, E, S (non-US market), GLK, GLE and GLS.
I actually own both currently. I have an 06 E350 w the 272 as well as the new-to-me GLK 350 with the 276. The E is so smooth and refined feeling and power is ok. The 276 in the GLK sounds worse idling (DI) but man! when you hit that gas pedal on that G all you say is “M two seventy who!!”
Any M272 after 2008 is a very good engine. Well maintained they are going 200k+ miles. The M272 is loosely based on the M112 which is one of MB’s “forever” engines with some W210 cars documented at 1 million miles.
There are well maintained M276 engines going 300k+ miles. The M276 engine 60 degree V is naturally balanced and inherently vibration free. It is a more compact design so spark plug maintenance is more complicated.
As far as the Chrysler Pentastar vs M276: Chrysler got the Pentastar V6 predecessor by cloning a 3.0 liter Mitsubishi engine from the 90s. It was basically a failure with internal valve train and piston wobble problems. Extensive rework resulted in the Pentastar around 2010-2011. The M276 is not related.
Any car with an M276 will be newer than one with an M272, but not necessarily lower mikes or better maintained. Either of these engines is a good choice and the condition, mileage, and maintenance history should be the deciding factor.
The following 4 users liked this post by Odd Piggy:
GLk350: 302 HP, 4.4:1 1st gear
E350: 268 HP, 3.6:1 1st gear.
No contest.
The following 3 users liked this post by Odd Piggy:
The following 3 users liked this post by Chris1979:
Received 2,603 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
All White Merc (Today)
Mercedes C350 4matic 2015
Great work from the author ..
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
